Is it normal my 3 to 1 PWM splitter is missing a pin on 2 connectors?
Solved by Samppa221,
It's the pwm pin you cant split it.The other 2 fans will only be running from the 3 pins.
Wallet_Warrior ·
Posted in New Builds and Planning3 -
Lehrules ·
Ronin_Noble ·
ShadoSgt ·
5
3
1
300DaysToGTA6 ·
Posted in Graphics Cards0
play_circle_filled
Latest From Linus Tech Tips:
I Want A Job At The Roblox Store - WAN Show June 7, 2024
