I'm considering the new Phanteks case for my first PC, and I would like to hear opinions.
Since Linus hasn't reviewed the case yet, I'd like to hear what you guys and gals have to say about it.
Code-name Nyx: R7-3800X w/ Scythe Fuma 2 Rev. B | Sapphire RX 5600XT | Gigabyte B550i Aorus Pro AX | Patriot Viper 4 Blackout | 3TB NVMe Storage| Cooler Master NR200 | Kubuntu/Windows 11 | Xiaomi Mi Curved 34" | Keebwerk Mega | Logitech G602 | Audio Technica ATH-M40X| Edifier e25 Luna
https://linustechtips.com/topic/488496-enthoo-pro-m/
Its one of the highest rated cases around for most review sites :o
I was considering either the Enthoo Pro or the Coolermaster MasterCase 5. Fortunatly they came out with a cheaper, and smaller case (cause I don't have alot of room by my desk, it will have to sit on top...) with the same sexy design.
I saw the review that hardware canucks made and I like the new case.
tbh though, I am slightly bumed out, cause I LOVE the Master Case, but it puts me way out of my budget...
https://linustechtips.com/topic/488496-enthoo-pro-m/#findComment-6556160
Most of the time cases are about style and added features that arent needed. You should never have to spend more than 130$ at most for a case. There is just no point unless your doing a full custom water loop build and need a massive custom case. All you need is 2-3 front fans, 1 exhaust, and 1 psu fan on the bottom, with a mount on top or in front for a RAD for your CPU Liquid cooler or if your air cooling you dont need top fans, they dont really add anything.
https://linustechtips.com/topic/488496-enthoo-pro-m/#findComment-6556185
