Question about 2.1 audio
I'm looking at this set of 2.1 cheap speakers from Edifier and my question is will this be compatible with my gigabyte board? because the specs sheet says that it only supports 2/4/5.1/7.1-channel. But I was thinking, since it supports 5.1 shouldn't 2.1 support be a given? i'm not an audiphille so i'm not too sure about all these things. Thanks
the speakers are here: http://www.edifier.com/int/en/speakers/m1360-2.1-computer
and this is the mobo im looking at: http://www.gigabyte.com/products/product-page.aspx?pid=5493#sp
CPU: Intel i5 6500 Motherboard: Asus H170M-E D3 Memory: Kingston HyperX Fury DDR3 2x8 GB GPU: -NIL- SSD: Samsung 850 Evo 250GB HDD: HGST Deststar NAS 3TB Case: Corsair 240 Air Power Supply: Seasonic M12II Evo 620W Display: Dell U2515H 25" 2560x1440 Keyboard: Corsair Strafe (Red LED + Cherry MX Brown) Mouse: Logitech Performance MX Speaker: Edifier M1360 2.1
https://linustechtips.com/topic/488305-question-about-21-audio/
yeah it should
it uses a realtek driver, whch does support 2.1
https://linustechtips.com/topic/488305-question-about-21-audio/#findComment-6553505
Yes this is a very simplified approach to a "2.1" setup. That motherboard is going to work just fine.
https://linustechtips.com/topic/488305-question-about-21-audio/#findComment-6553683
