A PC built for my friend in December of 2014 has had issues in the past with a motherboard but the problem was fixed.
The new issue for this PC is that it now has flashes on the monitor, extreme tearing, and random displays of chronological colors.
I have tried unplugging the webcam, the keyboard/mouse, changed the keyboard/mouse, changed the monitor, used 2 monitors at one point, and switched the channel the ram was in.
I think it may be the GPU but I am unsure.
The cable can't be the problem either because it is one display port I and one HDMI for each monitor tested.
I wanted to check the temps but the PC will not go past the MOBO screen unless it is to the recovery screen, in which case it glitches out until the screen goes windows 8 light blue.
This PC runs Windows 10, has a R9 270X, has a 970 MOBO, 6300 CPU, some 1600 RAM I can't remember atm, a 650w PSU, and a terabyte hard-drive.
(MOTHER BOARD DOESN'T HAVE ONBOARD GRAPHICS SUPPORT)
So again, my only thoughts are:
  1. Ram
  2. CPU
  3. Cooling
  4. GPU
If you can help please do, below are some videos of some of the problems.
WIP Build (Maul):
| CPU: R5 3600 | AIO: Stock GPU: Undecided (Vega 56 prob) MB: B450M RAM: 32gb 16x2 DDR4 3000mhz | PSU: Undecided HDD 1TB m.2 SSD | Case: Inwin 301 | $800-1000 PCPartpicker
Old Build (Vader):
| CPU: FX 8350 | AIO: h100i GPU: G1 GTX 970 MB: 990FXA-UD3 RAM: 8gb Vengence LP 1600mhz | PSU: EVGA 500B HDD 1TB x2 & 120GB Kingson SSD | Case: NZXT Noctis 450 |
Idle: 11-17c, Browsing: 13 - 23c, Load: 22 - 39c | Fedora & Arch Linux | $1,053 PCPartpicker
https://linustechtips.com/topic/488262-odd-crash-is-occuring-please-help/
Remove the GPU and plug the video cable into the motherboard. See if it displays normally. If so, then the GPU was the issue. Alternatively, if you have a different GPU, plug that in and see how it works.
CompTIA A+ Certified
"We are all cups, quietly and constantly being filled. The trick is knowing how to tip yourself and let the good things pour out." - Ray Bradbury
Nevermind. I missed the "no onboard graphics" portion and can't edit my other post from my phone. Sorry about that. Still, try putting a new GPU in there.
