Cutting Costs?
Go to solution Solved by CornOnJacob,
Do not cut when building your own loop, performance will not be adequate and components will not be of good quality.
  • Forget the pump Bitspower pump top, just use the normal top. (buy a more reasonable res)
  • Use soft tubing with EK fittings.
  • Drop the valve (and two fittings)
  • Use XSPC/EK coolant
  • Drop the dye
I think Samdb is right. As much as I want to save money, I'd rather build the rig I want and have to save up more. Thanks for your help guys :)
Hello,
    I have a question on how to cut costs when building a loop. I just added up the cost of my water cooling components and not including radiator fans, lighting, or a GPU backplate, it comes to roughly $625. :(
    This pricetag seems kind of absurd, but I don't know what to cut out. I have reasons for what I picked (e.g. I picked hard tubing because of aesthetics and mainly the fact that it wont degrade with dyes/coolants). I don't want to water cool just for performance (although the OCs will be nice), I want to watercool to get a silent, and most importantly, awesome looking system. Is there a way to cut this down or do I just need to accept the fact that watercooling "the right way" comes with a hefty price tag?
Here are the parts I was looking at:
[spoiler=]
EK Supremacy Clean CSQ Nickel Plexi CPU Block
EK Clean CSQ Nickel GTX 770 Block
Alphacool NexXxoS XT45 240mm Radiator x2
Swiftech MCP655 Pump
Bitspower Acrylic Pump Mod Top
Bitspower MCP655 Matte Black Mod Kit
Bitspower Water Tank Z Multi 150 POM Reservoir
PrimoChill Rigid Tube Fittings x10
Primochill 24in Rigid Tubing 4pack x2 (plus two additional fittings at $6.95 each)
Bitspower Mini Valve
Mayhem's X1 Clear Concentrate
Mayhem's Emerald Green Dye
[spoiler=My Current PC]AMD FX-8320 @ 4.2 Ghz | Xigmatek Dark Knight Night Hawk II | Gigabyte GA-990FXA-UD3 | 8GB Adata XPG V2 Silver 1600 Mhz RAM | Gigabyte 3X Windforce GTX 770 4GB @ 1.27 Ghz/7.25 Ghz | Rosewill Hive 550W Bronze PSU | Fractal Design Arc Midi R2 | Samsung Evo 250 GB SSD | Seagate Barracuda 1TB HDD | ASUS VS239H-P | Razer Deathadder 2013 Partlist
LTT Build-Off Thread: http://linustechtips.com/main/topic/35226-the-ltt-build-off-thread-no-building-required/
https://linustechtips.com/topic/48807-cutting-costs/
https://linustechtips.com/topic/48807-cutting-costs/#findComment-649231
Use XSPC/EK coolant
Drop the dye
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/48807-cutting-costs/#findComment-649274
  • Drop the dye
I'll take all of these into consideration--thank you.
If I drop the valve, I would need quick disconnects which wouldn't save me much money. How can I drop the two other fittings? I thought I needed two per radiator, two for the CPU block, two for the GPU block, and two for the pump/res. If I dropped the mod kit, I would actually need two extra fittings (to go between the pump and res).
https://linustechtips.com/topic/48807-cutting-costs/#findComment-649294
@Ghost @Samdb
Do you guys recommend buying parts secondhand? If so, which ones?
https://linustechtips.com/topic/48807-cutting-costs/#findComment-649394
@Ghost @Samdb
I wouldn't buy second hand components, you can't really guarantee the quality of them.
https://linustechtips.com/topic/48807-cutting-costs/#findComment-649416
  • Drop the dye
https://linustechtips.com/topic/48807-cutting-costs/#findComment-649446
