I just turned off my system to install a new dust filter on one of my fans and when I turned it off suddenly turned back on, back off and back on again to tell me that I needed to reset the, what I think was, motherboard settings to default as it had a problem. This then caused my CPU to downclock to 3.5ghz from 4ghz.
Now when I booted up my CPU was at 100%, it has now gone down to 20% so it may have just been due to boot up.
What could have happened?
CPU: FX-6300 GPU: Sapphire R9 380X MOBO: Gigabyte 970A-DS3P RAM: Corsair Vengeance 8GB PSU: XFX XTR 550W CASE: Zalman Z11 Plus SSD: Samsung 840 Evo
17 years old, PC Enthusiast for 3. Be gentle with me, I'm only young.
https://linustechtips.com/topic/488069-cpu-issues/
you jumped the BIOS?
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/488069-cpu-issues/#findComment-6550623
Okay, looking at task manager it says my maximum speed is 3.5ghz but its reaching 3.75+ at times. What is going on?
https://linustechtips.com/topic/488069-cpu-issues/#findComment-6550633
Wat dat
https://linustechtips.com/topic/488069-cpu-issues/#findComment-6550634
Wat dat
you should see a watch battery in the motherboard, usually around the PCI slots.
with the PC and PSU off, take it out, wait 10 seconds, and put it back in in the same orientation, it will reset your BIOS.
i has a similar issue of a boot-failure reboot cycle, this fixed it.
it could also be your previous OC was greatly increasing perofrmance
Solitaire.
https://linustechtips.com/topic/488069-cpu-issues/#findComment-6550648
I'll reboot again and see if it does a similar thing, not sure if it was just a one off.
That's what I was thinking but it's still reaching higher speeds then 3.5 for some reason? I'm so confused
https://linustechtips.com/topic/488069-cpu-issues/#findComment-6550664
Rebooted, went into bios, selected optimization defaults. Speed is still reaching higher than 3.5 in task manager yet it says the max is 3.5?
https://linustechtips.com/topic/488069-cpu-issues/#findComment-6550725
