Best monitor under 150?
skillzandroid
What is the best monitor I can get for under $150.. I could spend a little more if necessary but I want something that will perform good and has no back light bleed.
All LCDs have backlight bleed, it's an inherent issue with the technology. The only consideration is whether the bleed is uneven or not, which is on a unit-by-unit basis, it's not determined by what model you get.
Probably the Acer H236HLbid is one of the better options in that price range. The H226HQL is a slightly smaller option if the H236 is too much.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236307
im using this one as we speak. I love it because it fit my budget perfectly.
it not the best obviously, but for gaming at its price its great,
viewing angles are pretty decent,
its cheaper on amazon usually
also image bleed is only on black or dark blue screens, like say in game at night time you can see it,
but its not like BLAM HI HOW ARE YOU
it is not noticeable if your into your game
