so im trying to put files from my hdd to onedrive to i can transfer it to another computer, but when im copying files to onedrives its also puttin it on my ssd, which is taking up alot of space, i yhough onedrive was all cloud ? why is it on my ssd ?
The Ninja (current gaming pc)  Case- h440 red/black cpu- i5-4690k@ 4.3ghz cooler- coolermaster hyper 212 evo moboGigabyte z97x-sli ram- adata xpg v.1 2x4gb 1600mhz gpu- asus strix gtx 970 hdd- wd blue 1tb ssd- kingston hyperx savage 240gb psu- evga 600b peripherals: mouse- razer death adder 2013 keyboard- corsair k70 with chery mx-reds headset- HyperX Cloud 2
my laptop- toshiba satelite p850, cpu- i7-3630qm ram- 8gb 1600mhz hdd- 1tb 5400rpm gpu- Nvidia gt630m 2gb
did you know we have a gun thread ? well we do
and a car thread !
https://linustechtips.com/topic/487627-onedrive-questions/
It's probably a setting you have on the other computer.
maybe i wast clear, the ssd and the hdd are in the same pc :/
and a car thread !
https://linustechtips.com/topic/487627-onedrive-questions/#findComment-6544685
One drive saves a local copy on all PC's to ensure you always have a copy and it syncs online and with all other devices to update the files. You can change the location of the onedrive folder but you need to un-sync and re-sync your one drive on your pc it will prompt you with an option to where you want to saved files to be located.
https://linustechtips.com/topic/487627-onedrive-questions/#findComment-6544785
ok I'll try moving the file tonight then
and a car thread !
https://linustechtips.com/topic/487627-onedrive-questions/#findComment-6547713
