Low PPD?
Go to solution Solved by Extingquish,
Yep that's normal, not exactly sure where you got that it was low
I'm assuming you're comparing your 390 to a 970, and the reason they can pull more points is that the program is simply more optimized for the hardware, and vice versa
I am folding with my msi r9 390, and i5 4460, and I am only getting around 200,000 PPD. Is this normal?
PC SPECS: CPU: i5 4460, MOBO: Asrock H97 Anniversary, RAM: G.Skill Ripjaws X 2x8GB, GPU: MSI Gaming R9 390 8GB, CASE: Cooler Master N200, Storage: 1TB WD Blue, PSU: Coasair CX600
Active Folder
https://linustechtips.com/topic/487493-low-ppd/
Specs: CPU: AMD FX 6300 Motherboard: Gigabyte 970A DS3P RAM: HyperX Fury 16GB 1866MHz GPU: MSI R9 270 OC edition Case: Sharkoon VS3-S SSD: Samsung 840 EVO 120GB HDD: 1TB Caviar Blue PSU: Corsair CX500W
*If I say something that seems offensive, please don't take it seriously, it was most likely meant as a joke/sarcastically*
https://linustechtips.com/topic/487493-low-ppd/#findComment-6543402
