im currently building a haswell i5 4670k procie with a z87 sabertooth motherboard, 8gb corsair vengeance pro series 1866 Mhz, kraken x60 AIO and a palit geforce gtx 780 super jetstream  videocard.
here in the philippines, a store here offered 50% off of a Corsair AX 1200 Gold PSU (NOT THE i VERSION), and he also have in stored are Seasonic x750 and x850w.
these are the prices:
Corsair AX 1200 = roughly $187
Seasonic x750   =  roughly $170
Seasonic x850  =   roughly $193
i know its way to overkill if i choose Corsair AX 1200 on my system but who knows, i might be going into 780 sli in the future..and also it got a lot of headroom for overclocking and upgrading.
so please help me decide.. thank you
https://linustechtips.com/topic/48743-help-me-choose-a-psu/
The 750w is plenty, even if you want to go SLI. The 1200w would be for something like quad SLI or some crazy setup, which your current parts don't even support.
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
https://linustechtips.com/topic/48743-help-me-choose-a-psu/#findComment-648253
ax1200w just get it, its awesome and well its awesome.
Listen if you care.
https://linustechtips.com/topic/48743-help-me-choose-a-psu/#findComment-648257
Is there any lower end corsair psus that are on sale as well?
Cpu: Intel core i5 4570 gpu: gtx 770 case: cm storm enforcer psu: xfx pro 550w motherboard: asus b85m-g ssd: samsung 120gb hdd: wd caviar blue 1tb ram: kingston hyperx blu 8gb 1600mhz mouse: razer deathadder monitor: some decent samsung 19" keyboard: CM Storm TK Blue
https://linustechtips.com/topic/48743-help-me-choose-a-psu/#findComment-648276
The new haswells don't take a lot of volts. I would go for the Seasonic x750 its nicely modular 80plus gold and its the chepest you have listed there. As mcuh as i would say go for the Corsair 1200w ( I have the ax860 ) its just way to over kill.
Asus Maximus VI Hero , i5 4670k , 8gb Corsair vengeance ddr3, Asus HD 7970 matrix platinum, Corsair AX860, Ocz agility 3 120gb ssd, 1tb wd green hdd, custom water loop. All in an Antec p280
https://linustechtips.com/topic/48743-help-me-choose-a-psu/#findComment-648381
they got a Corsair AX 750 on sale also
im diggin the AX 1200.. its really a steal!
Go for the AX 750 then. That'll be cheaper and if you decide to go SLI in the feature, it will handle it fine with room for water cooling and overclocking.
CPU: 5930K @ 4.5GHz | GPU: Zotac GTX 980Ti AMP! Extreme edition @ 1503MHz/7400MHz | RAM: 16GB Corsair Dom Plat @ 2667MHz CAS 13 | Motherboard: Asus X99 Sabertooth | Boot Drive: 400GB Intel 750 Series NVMe SSD | PSU: Corsair HX1000i | Monitor: Dell U2713HM 1440p monitor
https://linustechtips.com/topic/48743-help-me-choose-a-psu/#findComment-648455
