HELP DRAM LED BLINKING
Go to solution Solved by KenLeeJL,
Apparently my comp only like one stick and now 2.
RAM isn't detected. Try reseating it, or putting it in another slot.
|My Rig| |Intel Core i5-6600K @ 4.70GHz| |GT 740| |16GB Kingston HyperX Fury 2133MHz| |240GB PNY SSD, 1TB WD Blue (RAID 0), 320GB Backup Drive| |Corsair 600C| |EVGA Supernove 850 G2|
https://linustechtips.com/topic/487359-help-dram-led-blinking/#findComment-6540946
Dual Channel? Make sure your ram sticks are in the same color RAM slots. Use the ones marked with red.
coudn't help but notice the cool and unique signature !
I like it
https://linustechtips.com/topic/487359-help-dram-led-blinking/#findComment-6540978
I can assure both ram are working and all slots are working but when in dual channel its not. Im using Hyper X Fury DDR3 2400MHz
You somehow managed to fit DDR3 memory into a DDR4 board? :huh:
https://linustechtips.com/topic/487359-help-dram-led-blinking/#findComment-6541099
