I've got a Novation Launch Pad pro, and I'd like to finally learn how to use it.  Does anyone have suggestions for resources for learning how to use a MIDI controller, good free software that is at least some what intuitive, and any extra tips?  Thank you.
I'm playing my Xbone on 3 LG Curved monitors-No one ever
Please, read CoC it helps, it helped me it should help you-Every competent member
Resident bad pun maker.....please excuse them
https://linustechtips.com/topic/487351-dj-help/
It already comes with Ableton Live Lite 9...
https://linustechtips.com/topic/487351-dj-help/#findComment-6540863
I know that, but should I pay for it?  Are there free options that rival the Lite version?  I have the money to spend on full fledged software but I won't be getting that into it.  It's merely a fun thing to play around with in my spare time.
https://linustechtips.com/topic/487351-dj-help/#findComment-6540883
Why do you need to pay for it if it comes for free with the launchpad?
https://linustechtips.com/topic/487351-dj-help/#findComment-6540893
There isn't a pro version I need to pay for?
https://linustechtips.com/topic/487351-dj-help/#findComment-6540924
well theres the full ableton suite...but if youre just doing this for fun the live lite version will be enough
https://linustechtips.com/topic/487351-dj-help/#findComment-6540933
I'm beginning to think that I should have opened the box, damn my poor foresight!
https://linustechtips.com/topic/487351-dj-help/#findComment-6540938
Thank you, now as far as learning to use it.  Would you say it's an intuitive experience?
https://linustechtips.com/topic/487351-dj-help/#findComment-6540942
i havent used ableton, but i hear its one of the best DAWs
https://linustechtips.com/topic/487351-dj-help/#findComment-6541027
