So i bought a seagate hybrid drive(SSHD) and I am wondering about how to install the OS onto the SSD portion of the drive. All help is apprciated
You can't.  The SSD is a cache and over time the firmware learns what you use the most and pre-loads them into the SSD portion.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/485776-help-with-sshd/#findComment-6512953
The ssd caching is automatically handled. You would install the OS on it like any other drive.
Moved to Storage Solutions.
https://linustechtips.com/topic/485776-help-with-sshd/#findComment-6512958
Umm they don't work like that it's only an 8GB NAND flash section used for caching data to speed it up compared to a regular HDD.
https://linustechtips.com/topic/485776-help-with-sshd/#findComment-6512959
Ok then, are SSHDs faster than normal hdds?
Marginally yes they are better for load times usually for things like windows but require to learn or remember the stuff to cache a few times first.
-https://www.youtube.com/watch?v=qEIp1jgKnv8-
https://linustechtips.com/topic/485776-help-with-sshd/#findComment-6512992
In terms of responsiveness, they're noticeably better than traditional hdd's but don't make as much of a difference as a dedicated ssd. Sequential transfer speeds are pretty much the same as a regular hdd.
https://linustechtips.com/topic/485776-help-with-sshd/#findComment-6513007
Ok so now im actually gonna buy a disk but should i get a SSHD or a HDD and what brand?
https://linustechtips.com/topic/485776-help-with-sshd/#findComment-6513013
It would help to mention what the system is being used for, where you're shopping/located, and budget..
Brand doesn't really matter without pricing--most hdd brands all offer good products.
https://linustechtips.com/topic/485776-help-with-sshd/#findComment-6513015
Im doing a gaming-work pc
Where are you shopping/located and what's your budget?
https://linustechtips.com/topic/485776-help-with-sshd/#findComment-6513025
Personally I like to recommend and SSD and HDD combo but if that's a bit over the budget an SSHD is a comprise of the two, you could always get a HDD and later on add in an SSD for your OS as an upgrade.
https://linustechtips.com/topic/485776-help-with-sshd/#findComment-6513027
Im in singapore and im looking for a 1tb drive under 100sgd
Can you link us to where you're shopping? How much storage would you need?
https://linustechtips.com/topic/485776-help-with-sshd/#findComment-6513033
Im going to Sim Lim square and 1tb.
No online shopping
Is there a price list you can link us?
https://linustechtips.com/topic/485776-help-with-sshd/#findComment-6513038
Nope. Im just gonna find the best value hdd. But im asking the forums on their views of a good value hdd.
Price and availability varies depending on where you're shopping. It's pretty much impossible to determine value without pricing.
https://linustechtips.com/topic/485776-help-with-sshd/#findComment-6513055
In SG it is 70sgd for a segate 1tb 7200rpm and 77 for a WD blue and 96 for a WD black
How much are the ssd's and sshd's?
https://linustechtips.com/topic/485776-help-with-sshd/#findComment-6513069
100+ for a 128gb
What about sshd's?
https://linustechtips.com/topic/485776-help-with-sshd/#findComment-6513102
98 for 750gb
$70 for the 1TB seagate hdd or $98 for a 750GB sshd both seem like good options depending on how much you'd like to spend.
https://linustechtips.com/topic/485776-help-with-sshd/#findComment-6513132
