More fans?
Go to solution Solved by Enderman,
yes its called a fan splitter and you can get 3 or 4 pin ones
Oink!
This is going to be a stupid question.
So I'm buying a new fan, but my motherboard has only got three fan connectors (I currently have three fans) + two CPU fan connectors (main and optional).
Is there any adaptor that splits a single 4-pin connector into two other 4-pin / 3-pin connectors? Or do I have to buy some sort of fan controller?
Cheers,
The Slimy Pig.
https://linustechtips.com/topic/485377-more-fans/
https://linustechtips.com/topic/485377-more-fans/#findComment-6508083
Other systems I've built:
https://linustechtips.com/topic/485377-more-fans/#findComment-6508092
Oink!
Cheers,
The Slimy Pig.
You could buy a fan controller but there is a splitter for two fans into one header. I do not know about the other way around. There probably is though because there is an adapter for everything now. The fan controller you could buy for like 30 bucks on amazon.
https://linustechtips.com/topic/485377-more-fans/#findComment-6508093
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/485377-more-fans/#findComment-6508094
