First Build
Go to solution Solved by don_svetlio,
Seems like a good build to me
Hello,
I'm making a build in the near future and I hope someone can look over it.
My budget is 880€, I know it sounds weird but thats 900€  in Finland.
Should i get that PSU or a bit cheaper Seasonic 620W modular one?
[PCPartPicker part list](http://de.pcpartpicker.com/p/ngYRcf) / [Price breakdown by merchant](http://de.pcpartpicker.com/p/ngYRcf/by_merchant/)
Type|Item|Price
**CPU** | [intel Core i5-4460 3.2GHz Quad-Core Processor](http://de.pcpartpicker.com/part/intel-cpu-bx80646i54460) | €182.29 @ Amazon Deutschland
**CPU Cooler** | [Arctic Cooling Freezer 7 Pro Rev.2 45.0 CFM Fluid Dynamic Bearing CPU Cooler](http://de.pcpartpicker.com/part/arctic-cooling-cpu-cooler-freezer7prorev2) | €19.90 @ Caseking
**Motherboard** | [MSI B85-G41 PC Mate ATX LGA1150 Motherboard](http://de.pcpartpicker.com/part/msi-motherboard-b85g41pcmate) | €80.00
**Memory** | [Kingston HyperX Fury Blue 8GB (2 x 4GB) DDR3-1600 Memory](http://de.pcpartpicker.com/part/kingston-memory-hx316c10fk28) | €43.68 @ Amazon Deutschland
**Storage** | [Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive](http://de.pcpartpicker.com/part/western-digital-internal-hard-drive-wd10ezex) | €50.88 @ Amazon Deutschland
**Video Card** | [XFX Radeon R9 390 8GB Double Dissipation Video Card](http://de.pcpartpicker.com/part/xfx-video-card-r9390p8df6) | €336.94 @ Mindfactory
**Power Supply** | [super Flower Leadex Gold 650W 80+ Gold Certified Fully-Modular ATX Power Supply](http://de.pcpartpicker.com/part/super-flower-power-supply-sf650f14mg) | €114.90 @ Caseking
**Other**| Kolink Aviator| €60.00
 | *Prices include shipping, taxes, rebates, and discounts* |
 | **Total** | **€888.59**
 | Generated by [PCPartPicker](http://pcpartpicker.com) 2015-11-15 12:06 CET+0100 |
[CPU] i5-650 [GPU] MSI GTX 750 OC [RAM] Generic 6GB [MOBO] MS-7613 [HDD] WD Blue 1TB [PSU] Silverstone Strider Essential 500W [Next build Q1 2016 http://de.pcpartpicker.com/user/Presmo/saved/ ]
Please follow your own topics.
https://linustechtips.com/topic/485125-first-build/
Hello,
Type|Item|Price
Please use the BBCode (not the pcpartpicker logo thing) on the forum :)
also: that looks like a good build :)
https://linustechtips.com/topic/485125-first-build/#findComment-6505459
https://linustechtips.com/topic/485125-first-build/#findComment-6505465
Ok, will do.
https://linustechtips.com/topic/485125-first-build/#findComment-6505468
Use other PSU.
Plz.
Do it.
Super Flower Leadex are among the best PSUs on the consumer market with the 6-pack 2kW model being the highest wattage unit ever produced. Please, do not spread misinformation :)
https://linustechtips.com/topic/485125-first-build/#findComment-6505470
Use other PSU.
Plz.
Do it.
Can you suggest a PSU?
https://linustechtips.com/topic/485125-first-build/#findComment-6505471
Super Flower Leadex are among the best PSUs on the consumer market with the 6-pack 2kW model being the highest wattage unit ever produces. Please, do not spread misinformation :)
Sorry. Will just /s it then :P
Don't start a post without pc specs.
https://linustechtips.com/topic/485125-first-build/#findComment-6505475
Yours is fine - don't listen to him - he has no idea what he's talking about >.<
https://linustechtips.com/topic/485125-first-build/#findComment-6505476
If you can put an SSD in there and If you want to save money you don't need the CPU cooler unless you are buying OEM because they usually come with the stock cooler which is just fine.
if you are thinking of SLIing in the future or Overclocking take a look at Z97 mobos also.
https://linustechtips.com/topic/485125-first-build/#findComment-6505490
:P Don't hate PSU's aren't my thing anyways :D
I could buy a cheaper PSU but this one has LED lights! :D
https://linustechtips.com/topic/485125-first-build/#findComment-6505514
Does it make sense to buy the 750W version? Its 20 euros more
https://linustechtips.com/topic/485125-first-build/#findComment-6505518
Sure - future expandablity
https://linustechtips.com/topic/485125-first-build/#findComment-6505656
