New build will not display on monitor after I powered it down
Solved by spaiduhz,
Cable used? My previous monitor had a similar isue when i used a hdmi cable. Had to pull the cable out and plug it back in to turn it back on.
Ive since changed to a diffrent set using dport cables instead. Didnt give me that heartache.
Also, you want to see if turning off nvidia surround helps or na.
Featured Topics
ammar666 ·
Posted in Troubleshooting0 -
CurtisLee14 ·
Posted in CPUs, Motherboards, and Memory6 -
Sparky862 ·
Posted in Storage Devices2 -
4
tinpanalley ·
Posted in Networking0 -
DoughmanX_HD ·
Posted in Windows1 -
220VoltsallCore ·
Posted in Operating Systems4
