So im looking to upgreading soon, I currently have a Phantom X4 840 processer and a crappy motherboard.
Current build:
CPU: AMD Phenom II X4 840 3.2GHz Quad-Core Processor
Motherboard: ASRock N68C-S UCC Micro ATX AM3/AM2+/AM2 Motherboard
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive  ($69.00 @ CPL Online)
Storage: Hitachi Deskstar 5K1000 1TB 3.5" 5400RPM Internal Hard Drive
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($68.00 @ IJK)
Video Card: Asus GeForce GTX 960 2GB Video Card  ($295.00 @ Centre Com)
Case: Cooler Master 690 III ATX Mid Tower Case  ($119.00 @ Umart)
Power Supply: Cougar 760W 80+ Bronze Certified ATX Power Supply
Optical Drive: LG GH24NSB0 DVD/CD Writer  ($18.00 @ IJK)
Operating System: Microsoft Windows 10 Home OEM (64-bit)
Case Fan: Cooler Master JetFlo 95.0 CFM 120mm  Fan  ($13.50 @ Umart)
Mouse: Razer DeathAdder World of Tanks Wired Optical Mouse  ($59.00 @ CPL Online)
Headphones: Logitech G930 7.1 Channel Headset  ($158.00 @ Umart)
Speakers: Logitech Z506 155W 5.1ch Speakers  ($80.00 @ CPL Online)
Other: NZXT White LED Strips ($25.00)
Total: $918.00
Generated by PCPartPicker 2015-11-14 16:22 AEDT+1100
I'm looking to go Intel...The only problem is that I want a White and Black theme, I have the case (CM690III) and a Galax GTX960 (white) GPU, black 750 watt PSU and so forth...
The two PC Part pickers below will give the 2 examples I would like to get, but I just can not decide. Also if you can suggest a better motherboard that can be easily modded to be a white/black theme your welcome too.
Skylake Build:
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($325.00 @ CPL Online)
CPU Cooler: Phanteks PH-TC12DX_BK 68.5 CFM CPU Cooler  ($55.00 @ CPL Online)
Motherboard: Asus Z170-AR ATX LGA1151 Motherboard  ($245.00 @ Centre Com)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory  ($174.00 @ IJK)
Total: $799.00
Generated by PCPartPicker 2015-11-14 16:25 AEDT+1100
4690K Build:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($357.00 @ CPL Online)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($209.00 @ CPL Online)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR3-1866 Memory  ($129.00 @ CPL Online)
Total: $750.00
Now wen it comes down to the upgrade I want to be able to overclock, and I want it to look pleasing.
In my situation, what Config would you buy. Prices isn't too much of an issue..But I wont want to spend more then 800$ if possible.
My new Gaming PC.
Case: Coolmaster CM690III, Motherboard: Asus Z170-AR, CPU: I5 6600K 4.6Ghz, OS: Windows 10 HP 64 bit, RAM: X1 8GB G.Skill DDR4, GPU: Galax GTX 960 (Overclocked), Storage: Kingston V300 SSD 120GB(OS), X2 1TB 5400RPM HDD, 500GB Samsung 7200RPM HD, PSU: Cougar RS 750 Watt, Peripherals: Logitech G910 Orion Spark,  World Of Tanks Edition 2014 DeathAdder Razer Mouse And Mouse Pad, Sennheiser HD 518. , Palsonic tftv6042fHD, Logitech Z506 5.1 Surround Sound Speakers
https://linustechtips.com/topic/484672-need-some-advice/
I'd go with the skylake, ditch the AR
get a ASUS-A (looks the exact same basically)
Ditch the CPU cooler and get a AiO
Since you want everything to match you should get black ram then white ram interchanging
I relised it was AUD, nvm
https://linustechtips.com/topic/484672-need-some-advice/#findComment-6500860
If you want a black and white theme, go with 4x4 for your RAM and get two black and two white sticks.
Ok, sounds like a plan, Will mean less future-proofing  because I will be going down to 4X4GB but I think its worth it.
My new Gaming PC.
https://linustechtips.com/topic/484672-need-some-advice/#findComment-6500927
So which build though...Skylake or stick to what everyone knows and go 4690k?
My new Gaming PC.
https://linustechtips.com/topic/484672-need-some-advice/#findComment-6500933
If you can afford skylake than by all means. It is objectively better than Haswell. And you'll get the ddr4 upgrade out of the way meaning when you do need to upgrade again, that will be one less thing you need to get
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/484672-need-some-advice/#findComment-6501851
