(Hardware Help) Skyrim Bottleneck
Go to solution Solved by Guest Kloaked,
It's your CPU most likely. Your 960 should be running Skyrim with no problems.
Try overclocking the 6300 a little bit if you haven't, or if you're even able to (if you have a good heatsink). If that doesn't help then you'd need to get a better CPU/motherboard.
Hello there LTT Gaming! I am a obsessive modder for Skyrim who has pushed my system to its limit in terms of fps, without the use of uGrids for those wondering. I was wanting to know what a 'professional' opinion would be on what part of my system is causing a issue with my fps in game, although I do use a lot of mods most of them are weapon textures or trees and there aren't that many in comparison to the frame drops I am getting. On Vanilla Skyrim I usually get 60 fps but I do use V-Sync so I don't know what my uncapped fps is unfortunately but I can tell you that in my current modded state I am getting around 42 fps when there is barely anything happening in a remote area with no trees but in combat I sometime drop below 30 fps, now I originally thought that maybe it was my graphics card but after seeing the builds of some other skyrim players with worse Graphics cards than me I was confused. So basically, what do I need to upgrade and any suggestions on what to upgrade to.
CPU: AMD FX-6300
RAM: Hyper-X 2x 4GB (unknown speed as of now)
GPU: GeForce GTX 960 Windforce 4GB
HDD: Some Toshiba pile of crap
P.S. if you do end up suggesting any parts the other games that I usually play or will be playing are things like mmo's which are pretty CPU intensive (correct me if wrong).
Dota 2 player, MMO player and Skyrim Modder | CPU: AMD FX-6300 GPU: GTX 960 RAM: 2x4GB HyperX | Student currently studying Computer science, Maths, Physics and History :D
https://linustechtips.com/topic/484527-hardware-help-skyrim-bottleneck/
your mod list would help
its most likely your cpu
Love is patient, love is kind. It does not envy, it does not boast, it is not proud. It does not dishonor others, it is not self-seeking, it is not easily angered, it keeps no record of wrongs. Love does not delight in evil but rejoices with the truth. It always protects, always trusts, always hopes, always perseveres.1 Corinthians 13:4
Can't possibly overclock my 6300, the only fans that I have in my case are the stock heatsink and the graphics card built in fans. It's a budget PC that I got for Christmas 2 years ago now. Which brand of CPU would you say that is better for gaming in general Intel or AMD? I've heard that the hyper-threading that the i-7 uses can help when it is supported in games but that not many games support the function. I was thinking maybe the new i-5 K skylake processor but I really don't know xD
FX-6300, eh?
That might be your problem.
Sobs in the corner because FX-6100...
DAYTONA
PROCESSOR - AMD RYZEN 7 3700X
MOTHERBOARD - ASUS PRIME X370-PRO
RAM - 32GB (4x8GB) CORSAIR VENGEANCE LPX DDR4-2400
CPU COOLING - NOCTUA NH-D14
GRAPHICS CARD - EVGA NVIDIA GEFORCE GTX 980Ti SC+ ACX 2.0 w/ BACKPLATE
BOOT and PROGRAMS - CORSAIR MP600 1TB
GAMES and FILES - TOSHIBA 2TB
INTERNAL BACKUP - WESTERN DIGITAL GREEN 4TB
POWER SUPPLY - CORSAIR RM850i
CASE - CORSAIR OBSIDIAN 750D
Even an i3 would yield better results for you. If you can figure out a budget for upgrades, we can help.
FX-6300, eh?
I have to say that I have heard nothing but bad things about it. Also, good to see a west yorkshire bud here :D
Thank you for the offer but budget will be fine, I have been saving up some money for a time like this, I have enough for a new CPU + Mobo + new heatsink.
Sweet! Which part of West Yorkshire?
DAYTONA
I'm from Wakefield which is actually really close to where you are. Spooky.
I go to Wakefield College for the Independent Game Development course there.
It's weird meeting someone on a forum that's nary ten miles away. :P
DAYTONA
Bloody hell that is spooky. I don't go to wakefield college but I do go to another local school very near there and a lot of my friends from 'high school' go there xD.
