Hi, i have been using my pre-built pc for about 3 months and there are some noticeable downfalls. its just a 500$ gaming rig that i got for my birthday. it was a good starter but christmas is coming and i want something more powerful. they old pc was using:
CPU- FX 4300 quad core
Gpu - msi gt 730
MOBO- a very shitty ms1 7x etc
Ram- un branded 8gb ddr3 sdram
1 tb- western digital blue (after market)
350 watt unbranded psu
the new build i want to do may be a little overkill but is ascetically pleasing.
cpu - fx 8350
gpu - evga gtx 960
mobo - msi 970 gaming
Ram - Kingston hyperX savage 2400mhz 2x4gb kit
case - cooler master master case pro 5
cpu cooler - cooler master 212 evo
psu - evga 500w 80+
hdd- 1 tb western digital blue (same one just moved to new computer)
Thanks let me know any changes that i could make to make this a better build for the same price point or same power for the lower cost thanks.
https://linustechtips.com/topic/484498-building-my-first-pc/
New psu, new CPU and new MOBO
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/484498-building-my-first-pc/#findComment-6498733
-snip-
Dont get an AMD CPU they are not nearly as powerful as an Intel i5 when it comes to gaming.
Skip the cooler
and get a EVGA 500w 80+ Bronze would be my recommendation as the lowest tier psu.
For GPU i would get the R9 380, its just more powerful if you can afford it. Preferably buy one from Sapphire, MSI or Powercolor, they have the most effective coolers.
https://linustechtips.com/topic/484498-building-my-first-pc/#findComment-6498758
What's your budget? If you're mostly gaming you really don't need a new CPU
https://linustechtips.com/topic/484498-building-my-first-pc/#findComment-6499070
