so my old psu decided to fail me so i bought a new one and i am not sure if this is advisable or safe but i removed the old one and just put in the new one with no fresh installs or anything
is this possible can i do it will it leave any errors?
so after it started up ok so i did a slight overclock by about a gigahert and whenever i started up it just gave me bsods is this to blame on the PSU?
https://linustechtips.com/topic/484423-random-bsods-help/
do you add more volts to the OC?
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
https://linustechtips.com/topic/484423-random-bsods-help/#findComment-6497836
you did a 1ghz overclock.. probably going to need to add vcore for stability... this is not a suprise. what cpu and cpu cooler?
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
https://linustechtips.com/topic/484423-random-bsods-help/#findComment-6497855
Probably your overclock is not stable. Test with Aida64. If it fails in the first 30min, then your system is not stable and you should compensate by adding more volts. Giving us your system specs will be helpful.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/484423-random-bsods-help/#findComment-6497866
ok i have a q6600
4 gigs of ddr2 800
evga 500w psu
p5k-ws motherboard
my oc settings were:
FSB 300
vcore 1.25
dram frequency 801mhz
dram voltage 1.9v
https://linustechtips.com/topic/484423-random-bsods-help/#findComment-6498052
