I can buy the XFX TS 750w gold for 90 euros or the Super Flower golden green HX 650w for 86 euros.I know that they are made by reputable brands,but would like to hear from the psu Gurus
Like you just said. Both very good brands. Go with the XFX in my opinion though. 4 extra euros for 100 more watts gives a bit more upgrade potential for the future.
https://linustechtips.com/topic/484354-help-with-psu/#findComment-6497195
-SNIP DO NOT QUOTE-
I'd get the Superflower if you're not planning to upgrade, since it's semi-modular.
GAMING PC "Ol' Bessie":
Ryzen 7 7800X3D | Radeon RX 9070 XT | Gigabyte B650M AORUS Elite AX | G.Skill Flare X5 6000MT/s CL36 16GBx2 | 5TB of SSD POWER | EVGA SuperNOVA 850W GT | Noctua NH-U14S | Fractal Design Pop! Mini AirCachyOS
Kind Of A Home Lab "Bay":
Ryzen 9 5900XT | Intel ARC A310 | ASUS PRIME B550-PLUS | T-FORCE 3200MT/s 16GBx2 + Corsair 3200MT/s 32GBx2 = 96GB!!! WOW!! | 2TB boot SSD + 8TBx6 HDD RaidZ2 | EVGA SuperNOVA 650W G2 | Phanteks Enthoo Pro M | Ubuntu 24.04 LTS
The Laptop:
Framework Laptop 13 | Intel i5-1340p | G.Skill Ripjaws 3200MT/s 16GBx2 | Solidigm P44 Pro 2TB | CachyOS
https://linustechtips.com/topic/484354-help-with-psu/#findComment-6497198
Yes,but it is 15 euros more expensive,so i don't think i can justify paying more for "slightly" better quality
Did you typo the OP? It says the TS is 90, and the Golden Green is 86.
I'd get the Golden Green. Again, it's semi-modular, so less cable mess.
EDIT- Oops, only the 750w and up is semi-modular. I'd get which one is cheaper.
The Laptop:
https://linustechtips.com/topic/484354-help-with-psu/#findComment-6497237
They're both great so get whichever one offers the best warranty.
https://linustechtips.com/topic/484354-help-with-psu/#findComment-6497718
Yeah as STRM said, just pick ethier which one appeals to you most, though the XFX one does offer a little extra juice if you ever want to add a 2nd card down the line. but both are pretty damn good PSU's.
Hey bro i like yo *vomits on you*
SpOOkY  - Intel Core i7 4820K - Sapphire Radeon HD 7970GHZ Toxic Edition 6GB - 16GB Corsair Vengeance 1600Mhz - Gigabyte X79-UD3 - EVGA Supernova G2 850W
My GrApHiCs DeSiGn TeAcHeR Is GoInG To bE sO MaD
https://linustechtips.com/topic/484354-help-with-psu/#findComment-6497880
