I recently bought a second hand HD4850 for $15 but my power power supply does not have pcie power.
I do not have much money. Trying to find one capable of powering my gpu. At least 450w. Thanks.
Can you buy a secondhand Seasonic or old Corsair TX or something like that?
https://linustechtips.com/topic/484283-cheap-power-supply/#findComment-6496124
google 450w psu. it's not difficult.
AMD A10 7700k APU @ 3.8 GHz  /  Dem Integrated R7 graphics  / 8 GB Crucial Ballistix DDR3 1800 MHz RAM  /  1 TB WD Black HDD  /  ARC Midi R2 Case  /  ASRock FM2A88M Pro 3+
Logitech MX Performance / Razor Blackwidow Ultimate
https://linustechtips.com/topic/484283-cheap-power-supply/#findComment-6496153
You'll probably just have to find an EVGA 500W PSU, given how they're perfect for budget oriented builds.
DAYTONA
PROCESSOR - AMD RYZEN 7 3700X
MOTHERBOARD - ASUS PRIME X370-PRO
RAM - 32GB (4x8GB) CORSAIR VENGEANCE LPX DDR4-2400
CPU COOLING - NOCTUA NH-D14
GRAPHICS CARD - EVGA NVIDIA GEFORCE GTX 980Ti SC+ ACX 2.0 w/ BACKPLATE
BOOT and PROGRAMS - CORSAIR MP600 1TB
GAMES and FILES - TOSHIBA 2TB
INTERNAL BACKUP - WESTERN DIGITAL GREEN 4TB
POWER SUPPLY - CORSAIR RM850i
CASE - CORSAIR OBSIDIAN 750D
https://linustechtips.com/topic/484283-cheap-power-supply/#findComment-6496157
When it comes to PSUs, you don't necessarily want to go very cheap. The best route for saving money is to look at XFX PSUs. Don't go with a Corsair CX or CS PSU, they're meant for low powered office machines and aren't very reliable.
END OF LINE
-- Project Deep Freeze Build Log --
Quote me so that I always know when you reply, feel free to snip if the quote is long. May your FPS be high and your temperatures low.
https://linustechtips.com/topic/484283-cheap-power-supply/#findComment-6496192
Bad idea. A cheap PSU that destroys all of your components holds much less value than a really nice one that doesn't.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/484283-cheap-power-supply/#findComment-6496298
then google "good 450 w psu"
https://linustechtips.com/topic/484283-cheap-power-supply/#findComment-6496314
I believe "reliable" would work better, but this is what I found:
Good: http://www.newegg.com/Product/Product.aspx?Item=N82E16817371045
Reliable: http://www.newegg.com/Product/Product.aspx?Item=N82E16817371045
Yes, they're the same PSU.
https://linustechtips.com/topic/484283-cheap-power-supply/#findComment-6496338
ay I'm using that in my build
https://linustechtips.com/topic/484283-cheap-power-supply/#findComment-6496354
Well, then, you chose well!  ;)
https://linustechtips.com/topic/484283-cheap-power-supply/#findComment-6496357
