CPU Temp Under Load
Go to solution Solved by gt403cyl,
All good in the hood there, you have room to OC.
I have a 120mm water cooler strapped onto my i7-3770k. Under load my CPU package temperature ranges from 45C-50C. Is this normal? I don't overclock.
Guide to GTX 900 Series: http://linustechtips.com/main/topic/457526-nvidia-900-series-basic-performance-guide/
Performance expert, building noob.
There is no such thing as excess in hardware.
https://linustechtips.com/topic/484125-cpu-temp-under-load/
