I have a build that im using a seasonic snow silent 1050watt, and a evga g1 1000 watt.
My problem is with everything installed my SATA power cables dont reach to the bottom where my HDD's/SSD's are mounted. I tried contacting cablemod for a full custom set but after weeks of very inconsistent delayed answers, Metric vs US standard confusion on there part and being quoted different prices for no apparent reason I will most likely just be buying extenders if possible.
So is there any downside to extenders? Are there certain ones that will work with my PSU's?? I know certain things use different gauges so which should i get? thanks!
TX10 Build Log: http://linustechtips.com/main/topic/456229-tx10-build-log/
Case: TX10-D   Proccessor: i7-5820k   MotherBoard: Asrockx99 Extreme4   Ram: Crucial Ballistix Sport 16GB (DDR4-2400)   GPU: Asus Strix OC 980ti   Storage: 850pro 500gb, 850pro 500gb, 850pro 256gb, WD black 16tb total, Silicon Power S60 120GB   PSU: Seasonic snow silent 1050   Monitors: Three of Asus VG248QE 144Hz 24.0"
https://linustechtips.com/topic/484007-custom-cable-help/
The downside depends on the quality, size, and the grade of those wires :)
Well any suggestions? Is there something that would match the wires that came with the PSU? This is going to be running like $2k+ in drives dont want it killing anything
https://linustechtips.com/topic/484007-custom-cable-help/#findComment-6485836
I have a build that im using a seasonic snow silent, and a evga g1 or g2 1000 watt.
My problem is with everything installed my SATA power cables dont reach to the bottom where my HDD's/SSD's are mounted. I tried contacting cablemod for a full custom set but after weeks of very inconsistent delayed answers, Metric vs inches confusion on there part and being quoted different prices for no apparent reason I will most likely just be buying extenders if possible.
For sleeved cables for specific PSU's Icemodz does stuff like this if you need extra long lengths. but as extensions in general something like theses will work:
http://www.amazon.com/Cable-Matters%C2%AE-Pack-Power-Splitter/dp/B012BPLW08/ref=pd_sim_23_5?ie=UTF8&dpID=41nYzua40HL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=0MPJKPVW6QF07B4H8Q6R
https://linustechtips.com/topic/484007-custom-cable-help/#findComment-6485839
Well I needed 60 inch cables and after I was quoted pricing and invoiced they said it suddenly changed because they thought it was cm not inches.... SOOOOOO are you sure icemodz can do 60 inch cables?? Any idea how much this would run?
https://linustechtips.com/topic/484007-custom-cable-help/#findComment-6485845
You can contact them for special orders to see what they can do, if you want you could make your if you want things exactly how you want, just make sure you state the units so there is no possibility of mix up.
https://linustechtips.com/topic/484007-custom-cable-help/#findComment-6485865
Ok thank you! Is there any downside to just getting extenders though? Like the one you linked?
https://linustechtips.com/topic/484007-custom-cable-help/#findComment-6485869
Basically as said if the cable quality isn't good or up to the proper size and extra connections. For such long runs in your cabinet case I would suggest going with the larger 16AWG wires since it will pose less resistance and problem if voltage drop was to occur. Sata cables aren't too hard also if you want to do them yourselves the only thing that's costly is to have the crimp tool for the PSU end if you were to make the cables. The sata connections just press/crimp into place onto the 5 wires to make an electrical connection.
https://linustechtips.com/topic/484007-custom-cable-help/#findComment-6485888
we are working on a UV Series right now which will also feature cable kits for the Corsair RMi/RMx Series - those kits will be available by the third or forth week of January!
oh cool, would you know if they will have white UV reactive cables? that would be awsome. then i would actually wait ;D
basically the white series, just reacting to uv lights in a blue or white way.
https://linustechtips.com/topic/484007-custom-cable-help/#findComment-6486111
Distance/Cable quality
So if i got 16AWG extenders itd be the exact same thing as just getting longer custom wires?
https://linustechtips.com/topic/484007-custom-cable-help/#findComment-6487697
use 16 awg if psu is 16 awg.
use 18 awg if psu is 18 awg.
you can go smaller to larger (psu --> extension) but not the other way around.
|My Rig| |Intel Core i5-6600K @ 4.70GHz| |GT 740| |16GB Kingston HyperX Fury 2133MHz| |240GB PNY SSD, 1TB WD Blue (RAID 0), 320GB Backup Drive| |Corsair 600C| |EVGA Supernove 850 G2|
https://linustechtips.com/topic/484007-custom-cable-help/#findComment-6487880
AWG is a measure of strand thickness within a wire. The smaller the AWG, the thicker the strands, the more current the wire can carry without losses. This is why you can use 16AWG with an 18AWG PSU, but not the other way around.
If in doubt, go 16AWG for your extensions.
Titan: Intel Core i7-5820K | ASUS X99-A | Crucial Ballistix Sport 4x4GB DDR4-2400 | ASUS Strix GeForce GTX 970 | OCZ Arc 100 2x256GB in RAID 0 | Seagate Barracuda 2x2TB in RAID 1
EVGA SuperNOVA 750 G2 | Fractal Design Define R5 Titanium Window | Phanteks PH-TC14PE | ASUS BW-12B1ST
https://linustechtips.com/topic/484007-custom-cable-help/#findComment-6487907
Any ideas where i can get SATA power 16AWG extensions? cant find them anywhere
https://linustechtips.com/topic/484007-custom-cable-help/#findComment-6487913
I have 8 hard drives being run off a single molex and 36" extension.  18awg is fine.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
https://linustechtips.com/topic/484007-custom-cable-help/#findComment-6487920
Well your still extending them, the main difference is the larger diameter since your cable is going through such a long run. Ideally if you were going to do custom cables I would suggest to have it all as the larger diameter.
https://linustechtips.com/topic/484007-custom-cable-help/#findComment-6488448
If you dont mind me asking which extender do you have? Running off what psu? Thanks!
https://linustechtips.com/topic/484007-custom-cable-help/#findComment-6492620
http://www.amazon.com/BitFenix-Alchemy-Multisleeve-4-Pin-Extension/dp/B006VKA4LI/ref=sr_1_8?ie=UTF8&qid=1432813304&sr=8-8&keywords=molex+extension
off a AX1200i 3 way molex splitter thats another 12".  2 of the milexes power 8 drives each and the third does my watercooling pumps and 8 fans for tje watercooling and drives.. i believe youll reach the current limit of the molex connector before the current limit of the wire.  im pretty close to the edge.
https://linustechtips.com/topic/484007-custom-cable-help/#findComment-6492721
