Friend of mine is getting a computer. 1080p Gaming, US. Willing to go $50 over, but would like for it to be avoided if possible. Needs monitor and os.
Type|Item|Price
**CPU** | [intel Core i5-6600K 3.5GHz Quad-Core Processor](http://pcpartpicker.com/part/intel-cpu-bx80662i56600k) | $253.99 @ Amazon
**CPU Cooler** | [Cooler Master Hyper TX3 54.8 CFM Sleeve Bearing CPU Cooler](http://pcpartpicker.com/part/cooler-master-cpu-cooler-rr910htx3g1) | $17.89 @ OutletPC
**Motherboard** | [MSI Z170A PC MATE ATX LGA1151 Motherboard](http://pcpartpicker.com/part/msi-motherboard-z170apcmate) | $89.99 @ Newegg
**Memory** | [Crucial 8GB (1 x 8GB) DDR4-2133 Memory](http://pcpartpicker.com/part/crucial-memory-ct8g4dfd8213) | $43.99 @ SuperBiiz
**Storage** | [Hitachi Deskstar 1TB 3.5" 7200RPM Internal Hard Drive](http://pcpartpicker.com/part/hitachi-internal-hard-drive-hde721010sla330) | $35.99 @ Amazon
**Case** | [Corsair 100R ATX Mid Tower Case](http://pcpartpicker.com/part/corsair-case-cc9011075ww) | $47.99 @ Micro Center
**Power Supply** | [XFX 550W 80+ Bronze Certified ATX Power Supply](http://pcpartpicker.com/part/xfx-power-supply-p1550sxxb9) | $54.29 @ Amazon
**Operating System** | [Microsoft Windows 8.1 OEM (64-bit)](http://pcpartpicker.com/part/microsoft-os-wn700615) | $84.99 @ NCIX US
**Monitor** | [Acer G227HQLbi 60Hz 21.5" Monitor](http://pcpartpicker.com/part/acer-monitor-umwg7aa001) | $109.99 @ Micro Center
**Other**| 7950| $110.00
 | *Prices include shipping, taxes, rebates, and discounts* |
 | **Total** | **$849.11**
 | Generated by [PCPartPicker](http://pcpartpicker.com) 2015-11-12 09:17 EST-0500 |
Buying the gpu used.
https://linustechtips.com/topic/483609-800-build-for-friend/
Type|Item|Price
No need for a 6600k if you're only getting a 7950. Someone will give you a better build.
My Gaming Rig;  Motherboard - ASUS Maximus VI Hero | CPU - Intel i5 4670k @4.5Ghz 1.25v | GPU - GIGABYTE GTX 980 @Stock | RAM -  16GB Corsair Vengeance @1866Mhz | CPU Cooler - Corsair H100i | Storage #1 - Samsung 840 Basic 250GB SSD | Storage #2 - Sandisk II 480GB SSD | Storage #3 - 2TB 7200rpm 64mb HDDPSU - Corsair HX750 | Case - Fractal Design R4 |
https://linustechtips.com/topic/483609-800-build-for-friend/#findComment-6487232
Type|Item|Price
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($172.89 @ OutletPC)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.50 @ Newegg)
Motherboard: Gigabyte GA-H81M-D3V ATX LGA1150 Motherboard  ($63.97 @ Amazon)
Memory: Patriot Signature 8GB (2 x 4GB) DDR3-1600 Memory  ($32.99 @ NCIX US)
Video Card: MSI Radeon R9 380 4GB Video Card  ($194.99 @ Newegg)
Case: Corsair 100R ATX Mid Tower Case  ($37.99 @ Micro Center)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($52.98 @ Newegg)
Monitor: Acer G227HQLbi 60Hz 21.5" Monitor  ($109.99 @ Micro Center)
Total: $752.18
Generated by PCPartPicker 2015-11-12 09:27 EST-0500
Get OS from G2A or Reddit. (way cheaper)
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/483609-800-build-for-friend/#findComment-6487268
It's just for compatibility  for possible future upgrades.
Total: $752.18
I'm one of those people who think it's illegal. Not really keen on buying os keys from random people on the internet.
https://linustechtips.com/topic/483609-800-build-for-friend/#findComment-6487627
Illegal? Buying it from G2A or Reddit is not illegal....
If you don't like buying it from other people then G2A is another option. Completely legit, as others will tell you.
Old Rig
https://linustechtips.com/topic/483609-800-build-for-friend/#findComment-6487698
And as some others will also say, it's not. I personally don't care if you buy from there or not, just personally don't think it's a good idea.
https://linustechtips.com/topic/483609-800-build-for-friend/#findComment-6491523
