50*C seems fine to me - what CPU is it?
I7 3770k and H100i GTX cooler
Hmm - are those load temps? If those are idle I'd suggest maybe cleaning the gunk out of the loop
I'm just watching youtube
What are max load temps? Try Cinebench or another CPU bench
CPU has no overclock
thanks for your help
One core on each processor always runs hotter than the others.
As for the rest:
Clean out the loop
Replace thermal compound
How many Case fans you got? Try and get one right next to your CPU if you can!
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
