anyone got anyway to make it faster because at the rate it is going it's gonna take longer to extract it than it did to download it... And my computer isn't exactly not powerful...
Any help would be great :D
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
https://linustechtips.com/topic/482526-winzip-extraction-taking-forever/
Use 7zip
seriously what are you extracting
I looked up some archive software benchmarks and 7z killed everything else
What are you extracting, where are you extracting from and where are you extracting to?
A game, that is in around 100 parts, which is a compressed ISO
my HDD to the Same HDD in the same folder
HDD speed is 7200 RPM, but even then the HDD is barely hitting 5% usage.
Current Build :
Laptop:
 CPU:
A game, that is in around 100 parts, which is a compressed ISOmy HDD to the Same HDD in the same folderHDD speed is 7200 RPM, but even then the HDD is barely hitting 5% usage.
are you downloading the 30gb gta5 with 30gb of viruses ?
Reading and writing to the same drive will effectively halve its speeds (likely worse than half) due to the nature of the process.
It's not unusual for a decent drive to be crippled by reading and writing at the same time.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
Its probably just having a hard time decompressing all those viruses in your pirated ISO ;)
Wait..pshhh no your not doing that my bad :P
Your CPU should be crushing that though, have you tried 7zip? it might just be an error within winzip
Or your hard drive is just actually getting wrecked and it says its not
exactly my thoughts, strange thing is my cpu is barely above 5% as well at 1.74GHz xD .
Transferring it to my SSD now so that should help alot, i think from now on they are going on my SSD's xD
Current Build :
Laptop:
 CPU:
So after transferring it to my SSD Raid 0 it's a little better but still not getting the speed i feel it should be.
https://gyazo.com/eac712e4d4c0a49abb5907c4cb2bdd1e
P, G and C are my raid 0...
Current Build :
Laptop:
 CPU:
