Code Name: ?????
http://ca.pcpartpicker.com/p/R39Gpg
Added the link instead of writing it down
*Edited it again so it has a 980ti*
*Edited it again since I got cheaper but better ram and motherboard*
*Edited it since I bought parts that weren't on the list*
J2LboTZ.jpg?1
Starting it next week friday (hopefully)
Main Rig
CPU: i7-6700k @ 4.9ghz | MotherBoard: Asus Maximus VIII Hero | GPU: EVGA SC GTX Titan OC'd | Case: 750D AirFlow Edition  | Power Supply: Corsair CX750M | RAM: G.Skill RipJaws V 4x8gb 32gb @ 2133mhz | Cooling: Corsair H115i GTX | Storage: 2 x WD Blue 2TB HDD
Girlfriend's Rig:
CPU: fx-6300| MotherBoard: Asus M5A97 | GPU: EVGA SSC ACX 2.0+ GTX 960 2GB | Case: Deep Cool Tesseract | Power Supply: Corsair CX500M | RAM: 8GB | Cooling: Hyper 212 EVO | Storage: 1 WD Blue 1TB HDD
https://linustechtips.com/topic/482460-skylake-build/
Its not just for gaming and im debating two 970s or one 980 and okay sorry about that :)
Main Rig
Girlfriend's Rig:
https://linustechtips.com/topic/482460-skylake-build/#findComment-6472442
Get neither. Go for a 980ti or 390x :)
FX-6300 cooled by Nepton 240M | EVGA GTX 970 SuperClocked | 8GB G.Skill ValueRAM | Cooler Master 690 III | Sharkoon WMP 500 Bronze
Power supplies:
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/ My F@h stats: http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=zyntaxable Intel vs. FX for gaming: http://linustechtips.com/main/topic/401217-more-updated-fx-vs-intel-for-gaming/
https://linustechtips.com/topic/482460-skylake-build/#findComment-6472446
The 980ti is significantly more than the 980 but I might get it if I get like one or two more customers soon for my website building company :D
Main Rig
Girlfriend's Rig:
https://linustechtips.com/topic/482460-skylake-build/#findComment-6472494
Ditch the RAM and just get some normal Corsair LPX. Dominator Platinum is over priced IMO, theres so little difference between it and any other RAM I just don't see where the extra price of it comes from ($100 Heat Spreader?)
Check it out for yourself - http://pcpartpicker.com/parts/memory/#m=11&Z=16384002&s=403000
Main Rig:-
Server:-
https://linustechtips.com/topic/482460-skylake-build/#findComment-6472524
Yeah I do admit that it's overpriced but I'm hooked on its design with the heat spreader :/
Main Rig
Girlfriend's Rig:
https://linustechtips.com/topic/482460-skylake-build/#findComment-6472542
Are you in Canada/Australia cause your prices are waaaaaay off.
I managed to do your build with the Gaming M5 instead of the M3, a WD HDD instead of the Seagate, a 980ti and Windows 10 and its still cheaper than yours.
http://pcpartpicker.com/p/pNJ7Vn
Ahh I see now, your in Canada.
Main Rig:-
Server:-
https://linustechtips.com/topic/482460-skylake-build/#findComment-6472589
Yeah I'm in Canada, its a lot more here.
Main Rig
Girlfriend's Rig:
https://linustechtips.com/topic/482460-skylake-build/#findComment-6472595
