Hi
Recently my EVGA GTX 770 SC gpu seems to be running hotter than usual.
Using msi afterburner i have noticed that at idle, my gpu starts at about 38 degrees celcius and increased into the high forties, the gpu fan is running at 48% speed.
My room temp is approx 20 degrees.
Anyone know if this is normal?
Thanks
(I regularly clean my computer so dust should not be the problem)
https://linustechtips.com/topic/482293-gtx-770-issues/
You could try to change the thermal paste on the cooler
https://linustechtips.com/topic/482293-gtx-770-issues/#findComment-6470289
Hi
Thanks
I've had a similar issue on my 770. The way to fix this is to turn off your PC. Then flip the switch on your PSU, wait 10 seconds or so. Then remove your graphics card from your PC. Unscrew all screws on it, remove the heatsink, clean off the old thermal paste and apply some nice fresh CM IC 2 or the equivalent. Make sure the size of the thermal compound is around the size of a pea. Then do the reverse off what i said so that your graphics card is back in your PC.
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
https://linustechtips.com/topic/482293-gtx-770-issues/#findComment-6470365
Thank You for your help:)
I will look into replacing the thermal paste.
https://linustechtips.com/topic/482293-gtx-770-issues/#findComment-6470386
Also , clean out hte heatsinks , that can't hurt.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/482293-gtx-770-issues/#findComment-6470680
