Hello people!
Im planing on getting a new rig, but its not as easy as i thougth. :D
Already got the case monitor and other stuff, so basicly just the internals.
This is what i got so far
http://pcpartpicker.com/p/rj72dC
My budget is 1000€~ and its only meant for gaming.
If you feel like tweaking the build or recommending something...
Go ahead! id really appreciate it!
Edit:
Case: Antec 900
Monitor: Flatron W224T
https://linustechtips.com/topic/481877-could-need-some-advice/
What monitor? And what case? And that's a relatively terrible PSU you chose due to bad components.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.99 @ Micro Center)
Motherboard: Gigabyte GA-Z97X-Gaming 3 ATX LGA1150 Motherboard  ($105.99 @ SuperBiiz)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  ($298.98 @ Newegg)
Total: $967.60
Generated by PCPartPicker 2015-11-09 12:08 EST-0500
Depending on your case you may not be able to use that CPU cooler. Also, overclock CPU please.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/481877-could-need-some-advice/#findComment-6464275
Edited partslist: http://pcpartpicker.com/p/rNQCxr
Better power supply and still under budget, You choose your HDD over your PSU not a good move at all m8. If your PSU is a bad one you cant expect the whole system to be a good one and its the thing powering up your 1000€ pc .
https://linustechtips.com/topic/481877-could-need-some-advice/#findComment-6464318
If you want the "Gaming" Motherboard get MSI H97 Gaming 3, using Z97 on non-K Motherboard is a waste, change the Memory to the normal Corsair Vengeance, change the HDD to SHDD for better performance, and change the PSU to EVGA G2/GS or XFX Pro Gold
Corsair CX have some issues with heat
actually its because the Poor Quality Compoment
Key Switches Guide | LLT Beginner Guide | GPU TDP & Power Consumption Explained | PSU Tier
s a d b o y s 2 0 0 1
https://linustechtips.com/topic/481877-could-need-some-advice/#findComment-6464325
He said 1000, and some of those parts aren't found in Europe I believe
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  (€177.88 @ Mindfactory)
Motherboard: ASRock Fatal1ty H97 Performance ATX LGA1150 Motherboard  (€105.00 @ Amazon Deutschland)
Memory: Corsair Vengeance Pro 8GB (2 x 4GB) DDR3-2400 Memory  (€61.73 @ Mindfactory)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  (€90.88 @ Mindfactory)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (€75.12 @ Mindfactory)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  (€317.89 @ Mindfactory)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  (€81.93 @ Mindfactory)
Total: €910.43
Generated by PCPartPicker 2015-11-09 18:21 CET+0100
Yeah I had a little moment of forgetfulness.
USEFUL LINKS:
https://linustechtips.com/topic/481877-could-need-some-advice/#findComment-6464382
Where are you from Europe exactly?
There is a possibility that some parts will be more expensive there or not sold there at all
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (€233.89 @ Mindfactory)
CPU Cooler: Corsair H100i GTX 70.7 CFM Liquid CPU Cooler  (€122.44 @ Mindfactory)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  (€89.89 @ Amazon Deutschland)
Memory: Kingston HyperX Fury Blue 8GB (2 x 4GB) DDR3-1600 Memory  (€44.16 @ Amazon Deutschland)
Total: €1056.20
Generated by PCPartPicker 2015-11-09 18:20 CET+0100
https://linustechtips.com/topic/481877-could-need-some-advice/#findComment-6464383
*Dumb post deleted*
i7 4790k | GTX 970 | 16GB
That's all you need to know. It's a beast.
https://linustechtips.com/topic/481877-could-need-some-advice/#findComment-6464398
And poor quality components lead to heat issues. It can only withstand 30C which isn't a lot.
how does even poor quality lead to heat ?
https://linustechtips.com/topic/481877-could-need-some-advice/#findComment-6464417
Hello people!
Edit:
Case: Antec 900
Yeah change the PSU!!!
If you want a reply PLEASE QUOTE ME!
WE NEED CUSTOM MEMBER TITLES AGAIN!!!!!
Member title post link!
https://linustechtips.com/topic/481877-could-need-some-advice/#findComment-6464438
The transistors and other components can withstand a certain maximum temperature depending on the parts used.
The parts used in the lower-end PSUs of Corsair are below the standards compared to XFX, SIlverstone, SeaSonic and EVGA at a similar price point.
These parts are usually made from outsourced companies like CapXon which is known for making low quality parts that can't withstand the high temps when under load.
I think what he meant was (poor quality = heating issues)
Corsair has nasty reputation in the lower-end and mid market:
http://www.tomshardware.com/answers/id-2321662/bad-opinions-corsair-series-cx430.html
http://www.overclock.net/t/1455892/why-you-might-not-want-to-buy-a-corsair-rm-psu
http://www.overclock.net/t/1431436/why-you-should-not-buy-a-corsair-cx
https://linustechtips.com/topic/481877-could-need-some-advice/#findComment-6464497
the video is meant for Sarcastic purpose, but it doesnt explain why you shouldnt get CX
CX Series is bad because its a Rebranding from CWT (Channel Well Techonology) that use poor quality compoment
https://linustechtips.com/topic/481877-could-need-some-advice/#findComment-6464540
