I would get this instead:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor (£165.41 @ Amazon UK)
CPU Cooler: Corsair H60 54.0 CFM Liquid CPU Cooler (£59.95 @ Amazon UK)
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard (£62.99 @ Ebuyer)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1600 Memory (£33.90 @ Amazon UK)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive (£59.29 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£39.10 @ Amazon UK)
Video Card: MSI Radeon R9 390 8GB Video Card (£264.97 @ Aria PC)
Case: NZXT Phantom 410 (White) ATX Mid Tower Case (£66.49 @ Aria PC)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply (£87.98 @ Novatech)
Operating System: Microsoft Windows 10 Home OEM (64-bit) (£72.30 @ CCL Computers)
Total: £912.38
Generated by PCPartPicker 2015-11-09 02:39 GMT+0000
I know it's haswell, but there really isn't a massive performance difference. Also you have chosen a non-OC motherboard with an overclockable CPU.
https://linustechtips.com/topic/481589-build-help/#findComment-6460124
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  (£199.99 @ Amazon UK)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  (£114.98 @ Amazon UK)
Memory: Corsair Vengeance LPX 8GB (2 x 4GB) DDR4-2400 Memory  (£41.20 @ Amazon UK)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  (£242.99 @ More Computers)
Power Supply: XFX TS 650W 80+ Gold Certified ATX Power Supply  (£58.26 @ CCL Computers)
Total: £955.58
Generated by PCPartPicker 2015-11-09 02:41 GMT+0000
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/481589-build-help/#findComment-6460126
@Killervolt because i dont know much about AMD tbh
Well . . . What do I say . . .
Many people on this forum have good experiences with AMD, myself included. Sure, they don't make the best CPU's but their graphics cards are reliable and competitive with Nvidia.
https://linustechtips.com/topic/481589-build-help/#findComment-6460174
@Killervolt would you say that the r9 390 is better than the gtx 970
At 1080p they trade blows. At higher resolutions the 390 starts to move ahead. Also keep in mind that the 390 has twice the amount of VRAM, which may be important for future games, if you want "futureproof-ness". But yes, I would recommend the 390>970.
https://linustechtips.com/topic/481589-build-help/#findComment-6460194
