You can purchase the switches online and you could replace them yourself but it would require some work.
This video should help you out.
It's not the switch; the LED is the only thing that isn't working. Otherwise, the N key is functioning normally.
Yes, I know but it is still the same process but you just have to unsolder the two small pins. This video shows the pins and also shows how to unsolder them.
Quote me to get a reply!
Could you link me to somewhere where I could buy the LEDs (white) please? ;)
Zealpc tends to have them. I bought a bunch of pink ones I was quite happy with. If you want the shape to match, you'd be looking for 1.8mm round leds.
Hey! New SIgnature!
I'm supposedly a person on the Internet, but you'll never know if I'm human or not ;)
