Sleeving for thermaltake?.
Solved by W-L,
I am planning a new build for christmas and am having trouble finding sleeving for pretty much everything
I have a thermaltake smart m850w and want red sleeving that isnt too expensive for anything really visible
Just thinking about it now makes me think that ill only really need sleeving for the PCIE power cables since thats the most visible thing.
Thanks in advance!
Sleeved extensions would be your best bet, especially since it's only a semi modular PSU. Some good ones are Cable Mod extensions, and Bitfenix Alchemy Cables.
