You should NEVER install drivers from anywhere else than the manufacturers website. ever.
"Never quote yourself"
        -I need a better name
https://linustechtips.com/topic/480995-please-help-rootkits/#findComment-6452216
So is it infected with virus'?
Did you run the scans? We don't know, we're not wizards. Run those scans and repot back.
https://linustechtips.com/topic/480995-please-help-rootkits/#findComment-6452237
how likely is it for a rootkill to infect my hardware?
0% likely.  It will infect the OS, which can be easily and quickly reinstalled at will.
https://linustechtips.com/topic/480995-please-help-rootkits/#findComment-6452329
First of all what seems to be the problem? Why do you think you have a rootkit on your computer?
My friend @babadoctor showed me a linustechtips TechQuickie video about rootkits and how if you install drivers from a different source than the manufacturers. You can get a rootkit. Then I started to panic. :C
Numbre
https://linustechtips.com/topic/480995-please-help-rootkits/#findComment-6452339
Honestly reinstall windows just to be safe, also if you have adware it is actually easier to reinstall windows than trying to remove the adware.
100% true, I got some adware one time and I ran AVG like 20 times and each time it found some more adware it made to sense, but it's gone now
My rig: Intel Core i7-8700K OC 4.8 | NZXT Kraken X62 | ASUS Z370-F | 16 GB Trident Z RGB 3000 (2x8) | EVGA 1070 SC | EVGA SuperNova NEX650G1 | NZXT H700 | Samsung 250GB 850-EVO | 2x 2TB Seagate Barracuda HDDs
https://linustechtips.com/topic/480995-please-help-rootkits/#findComment-6452342
I am still confused as to how he thinks there's a rootkit on his computer. Symptom, signs, he didn't even list it.
In any case, a fresh install wont do. Nuke the drive and then install the OS. Rootkit are know to persist after a install over a previous OS.
If death has no cost, life has no worth
The dead are gone, the living are hungry
Life is not about finding yourself, it's about creating yourself.
https://linustechtips.com/topic/480995-please-help-rootkits/#findComment-6452354
If you don't have symptom of a rootkit infection then you don't have it. If it ain't broke, don't fix it.
https://linustechtips.com/topic/480995-please-help-rootkits/#findComment-6452362
What are the symptoms?
To start off, the most common rootkit will disable your anti virus, change your admin level and eat your process. Install adware without your permission.
The nasty one will infect your bios, so reinstalling OS will do absolutely nothing. It will change your bios setting that can cause crash and fried gpu/cpu.
https://linustechtips.com/topic/480995-please-help-rootkits/#findComment-6452391
What should I use to nuke the drive?
Numbre
https://linustechtips.com/topic/480995-please-help-rootkits/#findComment-6452392
dban, I would consider taking another look before nuking the drive.. Also if you do nuke your hdd, I am not responsible for what you do.
https://linustechtips.com/topic/480995-please-help-rootkits/#findComment-6452415
What do you mean by taking another look? Also the drive doesnt really have anything on it. Can it physically stop my hard drive from working?
Numbre
https://linustechtips.com/topic/480995-please-help-rootkits/#findComment-6452419
TBH from the information you've given me, there is no rootkit on your computer.
Dban don't give a crap how empty your hdd is, if it's 1tb it will wipe the 1tb thoroughly.
https://linustechtips.com/topic/480995-please-help-rootkits/#findComment-6452450
