Help with formating the SSD
Go to solution Solved by Altecice,
open a command prompt as admin and type in:
diskpart
list disk
select disk # (whatever number your SSD is)
clean
select partition 1
create part pri
format fs=ntfs
assign
Dont do any of that those are your system partitions, you cannot format your system drive and expect good things to happen :( You will need to do a full new Windows install to 'fix' your issue.
hi guys i just tried to format my whole SSD because it was full of crap and i wanted to format it but when i did it it turnt out that it was split in 2 volumes 1 of 350mb another of 220ish GB and one with 450MB that isnt formated and i can´t format wich says "recovery partition" how do i format my SSD and make it back to one volume formated?
i add a photo of how it looks like
http://imgur.com/gallery/XwQOGXu/new
EDIT: Disk 0 its the SSD and before that happends i did a copy of the other HDD
CPU i5 4670K @ 4.2Ghz; MOBO Asrock z87 Pro4 RAM Kingston HyperX 2x8GB 1333Mhz DDR3 SSD OCZ 256GB HD Caviar Green 2Tb GPU Nvidia GTX 660 OC  Case Zalman Z11
https://linustechtips.com/topic/480980-help-with-formating-the-ssd/
delete the partitions of the SSD that you don't want.
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
diskpart
list disk
clean
select partition 1
create part pri
format fs=ntfs
assign
Quack 🦆
i cant delete the partition that its in the middle (the 450Mb one) i only have the option of "help"
diskpart
list disk
clean
select partition 1
create part pri
format fs=ntfs
assign
the SSD doesnt have the system, Disk 1 have the system dont worry about that
Try and use Parted Magic to essentially nuke the SSD.
That's......unfortunately all I really have, so if that doesn't work, then poo.
DAYTONA
PROCESSOR - AMD RYZEN 7 3700X
MOTHERBOARD - ASUS PRIME X370-PRO
RAM - 32GB (4x8GB) CORSAIR VENGEANCE LPX DDR4-2400
CPU COOLING - NOCTUA NH-D14
GRAPHICS CARD - EVGA NVIDIA GEFORCE GTX 980Ti SC+ ACX 2.0 w/ BACKPLATE
BOOT and PROGRAMS - CORSAIR MP600 1TB
GAMES and FILES - TOSHIBA 2TB
INTERNAL BACKUP - WESTERN DIGITAL GREEN 4TB
POWER SUPPLY - CORSAIR RM850i
CASE - CORSAIR OBSIDIAN 750D
dude that work, thanks mate... i love you dude... i love you
