Hi,
So I'm going into 6th form next year (UK) and have decided that I want a Microsoft Surface to accompany me.
Should I get the 3 or the Pro model? Have already decided that I don't want the 4 as its probably too expensive for my needs
Thanks!!
Future build:
http://uk.pcpartpicker.com/p/kGgNJx
Current build: (laptop)
Use the following style specs for your profile!
Specs:
Screeninator: Intel Graphics 5500
Stickaminator: Hyandai 12GB DDR3 RAM (1x8GB, 1x4GB)
Procrastinator: Intel i5-5500U @ 2.2 GHz
Noisoundacreator: TURTLE BEACH PX4
Remembrerthing: WD 1TB Blue HDD
Flat-Colorful-Thing: Samsung SyncMaster 2323Y
See-A-Move-O: Tecknet M288
https://linustechtips.com/topic/480398-surface-3-or-surface-pro-3/
The Pro 3 has better specs and comes with the pen. Those are pretty much the main differences in my mind. How much of those do you value?
The pen by the way is fantastic. I'm in University and you'll be amazed how many people actually have a Surface Pro variant for school. Extremely popular for writing notes with especially for math and science courses.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
Go for the Pro 3.
Surface 3 will allow you to take notes and light web surfing. It is powered by an Atom CPU after all.
The only advantage that the Surface 3 has over the Surface Pro 3, is sub-pixel tracking for the pen.
Beside that you are trading off, performance in all levels (storage drive, CPU, and GPU), takes longer to charge, no fully adjustable stand (just 3 levels), small screen resolution and screen size, and weaker Intel support on the drivers (from what I am noticing personally).
An advantage of the Pro 3 is that you can get the Surface Pro 4 keyboard with it for the improved trackpad, and keyboard.
The Surface Pro 4, while costs more (as the Pro 3 price drop), you have more CPU and GPU performance, and less throttling due to the much improve cooling, and improved CPU power efficiency. You also enjoy a better pen, with improved tracking, and pen tips that you can replace for different writhing feel. Although you can use the pen with the Pro 3 (you have to buy is separately of course, comes with the pen tips when you do), you will lose the improve tracking from my understanding.
Surface 3: Web browsing, note taking, MS Office crap, great for school work
Surface PRO 3/4: Photo/Video editing and rendering on the fly + the stuff the Surface 3 can do
Video games: NEITHER. Get a gaming desktop or laptop if you need the portability
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
Ok thanks for your help guys I think I will go with the Pro 3 :P
Future build:
Specs:
