i5 4590 temps
Go to solution Solved by ThinkWithPortals,
Alright, so I was wondering if my temps are normal. During basic web browsing, such as chrome with one or two tabs open, I am hitting about 50 degrees. During games, I hit about 67-70 degrees on my CPU. This is using the stock heatsink. I was considering either changing it out with a CRYORIG H7 or Corsiar H55. Do you think this is necessary?
If you're really unsure, you could reseat the heatsink to ensure it's on correctly, but that sounds about right to me. Just don't spend too much on a cooler if you get one, that CPU is locked after all. The Hyper 212 EVO from CM, be quiet! Pure Rock and Cryorig H7 are all great, relatively cheap air coolers.
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/480320-i5-4590-temps/
with stock heatsink that sounds fine. but what games and what cpu usage?
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
https://linustechtips.com/topic/480320-i5-4590-temps/#findComment-6443459
Usually GTAV or Just Cause 2 with a million mods, or Metro: Last Light
https://linustechtips.com/topic/480320-i5-4590-temps/#findComment-6443479
Other systems I've built:
https://linustechtips.com/topic/480320-i5-4590-temps/#findComment-6443482
sounds fine then.
https://linustechtips.com/topic/480320-i5-4590-temps/#findComment-6443490
