Airflow design in Carbide 300R
Solved by moity,
as long as you have this going on:
you should be fine.
I'm going to be using a 300R as well and I was planning to direct my CPU cooler (be quiet! PURE ROCK) to direct air out the back and put the rear stock fan to the top so it would exhaust air up. Then put a second fan alongside the stock front fan to help intake/push more air. But then I found a deal and decided to put two intake upfront and 2 rear exhaust - 1 in the back 1 uptop. After about 3-4 fans in a case it seems the temperature doesn't change by much.
