Im trying to spend as little as possible of a pc that will last for a long time and play the games i want to play. Are there any changes that i should make? https://pcpartpicker.com/parts/partlist/ NOTE im not adding an ssd. Thanks for reading
bad link
copy the part where it says permalink
CPU: i5 6600k @ 4.6 ghz  Motherboard: Asus z170-a  Cooling: Corsair h80i GT GPU: EVGA GTX 970  Ram: G.Skill 2x8 gb ddr4 2400  PSU: EVGA G2 Supernova 550w  Case: Corsair 200r Storage: 250GB 850 EVO + 2x wd 1 tb drives
https://linustechtips.com/topic/479774-gaming-pc-need-advice/#findComment-6435536
wrong llink
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/479774-gaming-pc-need-advice/#findComment-6435537
Im trying to spend as little as possible of a pc that will last for a long time and play the games i want to play. Are their any changes that i should make? https://pcpartpicker.com/parts/partlist/ NOTE im not adding an ssd or overclocking. Thanks for reading
Wrong link; use the 'Permalink' at the top of the part list in the edit view
https://linustechtips.com/topic/479774-gaming-pc-need-advice/#findComment-6435546
Im trying to spend as little as possible of a pc that will last for a long time and play the games i want to play. Are their any changes that i should make? im not adding an ssd or overclocking. Thanks for reading http://pcpartpicker.com/p/4Gnz3C
looks good
https://linustechtips.com/topic/479774-gaming-pc-need-advice/#findComment-6435571
What games you looking to play?
https://linustechtips.com/topic/479774-gaming-pc-need-advice/#findComment-6435590
You're missing a CPU Cooler, just keep that in mind. I do not believe that the Skylake CPU's ship with a cooler in the box, but I may be wrong.
https://linustechtips.com/topic/479774-gaming-pc-need-advice/#findComment-6435603
CPU: Intel Core i5-6600 3.3GHz Quad-Core Processor  ($215.99 @ SuperBiiz)
Storage: Crucial MX200 250GB 2.5" Solid State Drive  ($89.99 @ SuperBiiz)
Video Card: Asus Radeon R9 390 8GB Video Card  ($294.99 @ Newegg)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  ($61.99 @ SuperBiiz)
Total: $806.83
Generated by PCPartPicker 2015-11-05 18:40 EST-0500
https://linustechtips.com/topic/479774-gaming-pc-need-advice/#findComment-6435630
only the k series... hes getting a non k chip si it will come with a heatsink
With an SSD what benifits do i get besides start-up times?
if you load your games on it as well your loading times will be much faster as well
i put everything on ssds except for mass media storage, thats about the only thing i would use mechanical drives for any more
https://linustechtips.com/topic/479774-gaming-pc-need-advice/#findComment-6435652
I know how fast ssd's are compared to HDD's, but to me its not worth the $50 for faster load times
https://linustechtips.com/topic/479774-gaming-pc-need-advice/#findComment-6435677
Not sure either. Ill look into that, thanks
No you're good. I was corrected. I didn't see that you had a non-K skew. The 6600 does come with a heatsink so you don't really have to worry about it, unless you want to add another roughly $30 and get a hyper 212 evo
https://linustechtips.com/topic/479774-gaming-pc-need-advice/#findComment-6435678
I how fast ssd's are compared to HDD's, but to me its not worth the $50 for faster load times
it isnt only the load times though
ssds are quieter and last longer less chance of data loss
https://linustechtips.com/topic/479774-gaming-pc-need-advice/#findComment-6435687
If you are only wanting to play CoD I hate saying this but unless you get an amazing PC may want to consider a console. CoD has a long history of being terribly optimized for console.
PC SPECS: Athlon 860k, MSI 380 4GB, 8GB memory, 1TB HDD, Fractal Design Core 1000
https://linustechtips.com/topic/479774-gaming-pc-need-advice/#findComment-6435737
