How many FANS?
Go to solution Solved by vectorx5000,
3-4 IMO. Two front, one back, one top or bottom. Watch the video. I mean, the forum is actually for the channel.
How many fans should i put in my case?
Case:https: https://www.nzxt.com/product/detail/143-h440-performance-mid-tower.html
Fans i want to use: http://www.corsair.com/en-us/air-series-af120-quiet-edition-high-airflow-120mm-fan-twin-pack
*I'm overclocking my CPU & GPU
CPU: i5 6600k @ 4.6 ghz  Motherboard: Asus z170-a  Cooling: Corsair h80i GT GPU: EVGA GTX 970  Ram: G.Skill 2x8 gb ddr4 2400  PSU: EVGA G2 Supernova 550w  Case: Corsair 200r Storage: 250GB 850 EVO + 2x wd 1 tb drives
https://linustechtips.com/topic/479763-how-many-fans/#findComment-6435423
My Rig:
CPU: Intel i7 5820K @4.3 GHz; Mobo: MSI X99A SLI Plus; Cooler: Cryorig H5 Ultimate; RAM: 16GB HyperX Fury Black; GPU: MSI R9 380 4GB; Case: Fractal Design Define R5 Black w/ Window; SSD: Samsung 850 EVO 256GB and 500GB; HDD: WD Blue 1TB; PSU: EVGA 750W P2
Peripherals:
Monitor: LG 29UM57; Headset: HyperX Cloud II; Keyboard: Gamdias Hermes Mechanical; Mouse: Zowie EC2-A
https://linustechtips.com/topic/479763-how-many-fans/#findComment-6435432
i used all 7 slots on my h440 personally but replace the default 4 if you want
| NZXT H440 | AOC e2450Swd, AOC 2436V, RCA 42" LED TV | AMD 8320E | ASUS M5A97 R2.0 |MSI GeForce GTX 960 Titanium OC 4GB | Corsair CX 750 | 3 TB WD Green and PNY XLR8 240GB SSD | Windows 10 Pro | Ramaxel RMR5030ME68F9F1600 - 4GBx2 |Logitech G710+|Logitech G502 | Astro A40 | Blue Snowball Ice |
https://linustechtips.com/topic/479763-how-many-fans/#findComment-6435436
2 intake, 2 exhaust is more than enough.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/479763-how-many-fans/#findComment-6435446
btw, should i use 140mm or 120mm
140 if you can, the bigger the fan the slower it nees to spin to move the air meaning the quieter it is
https://linustechtips.com/topic/479763-how-many-fans/#findComment-6435478
140, but not a really big thing. Won't have a major impact.
My Rig:
Peripherals:
https://linustechtips.com/topic/479763-how-many-fans/#findComment-6435479
Bare minimum, I'd say 2 intake at the front and 1 exhaust at back. Just to keep positive pressure. As long as they're all running at the same speed too
EVE (My Gaming Build)
Motherboard: Asus Maximus VII Ranger - CPU: Intel i5 4690k @ Stock Speeds - Cooling: Phanteks TC-12DX - PSU: Corsair RM750 - GPU: MSI GTX 1070 - Storage: 1x 120gb Samsung 830 Evo SSD (OS Drive) | 1x 120gb Hyperx 3k SSD (Audio Editing) | 1x 480gb Sandisk Ultra II SSD (Games) | 1x 1TB Hard Drive (Mass Storage) - Case: NZXT Phantom 530 - Misc: NZXT Hue RGB LED and controller
https://linustechtips.com/topic/479763-how-many-fans/#findComment-6435492
  • 1 month later...
