Hi!.. Does someone have photos of their current rig with this case?..
I would love to change the side panel, making a bigger acrylic window to show all the inside...
Also I would like to make a custom PSU shroud for it...
Thanks!
I do.  What pics do you need?
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/479667-cm-storm-scout-2-modding/#findComment-6434191
Hi!.. some pic from the outside... did you modify it?.. I am looking for mod ideas...
Didn't modify anything, but I did remove all my drive cages.  Which sides do you need?  Anything particular I should take pics of?
https://linustechtips.com/topic/479667-cm-storm-scout-2-modding/#findComment-6434232
Do you have any plans of doing some mod?..
I would like a pic of the window's side!
Thanks!
I was thinking of maybe MAYBE doing something to fit a 360mm radiator to the top, but the case is getting a little small for my needs so I might just switch to something else eventually :P
http://imgur.com/fJXfqrp
https://linustechtips.com/topic/479667-cm-storm-scout-2-modding/#findComment-6434323
Do you still have the protective nylon?? LOL... I remove those things as soon as I opened it!!!
I tried to put a 240mm radiator on the top... impossible, it touch my motherboard..
Later I will post some pics of mine.
https://linustechtips.com/topic/479667-cm-storm-scout-2-modding/#findComment-6434396
Sshhhh, I like to keep stuff as new as I can :P  That plastic has been there for 3-4 years :P
https://linustechtips.com/topic/479667-cm-storm-scout-2-modding/#findComment-6434407
Wooow!!!!... I keep my stuff as new as I can also... I keep all boxes and that stuff... but not the nylons... I remove them instantly... It something stronger than me  :lol: ...
Talking about the case.. I'd installed all possible fans on it.. all of them Cougar 120mm (green/white leds).. they are controlled by a NZXT sentry 2... at low they are very quiet.
https://linustechtips.com/topic/479667-cm-storm-scout-2-modding/#findComment-6434461
If your interested I have a generalized guide here for adding in a window for your case under Window Mod:
http://linustechtips.com/main/topic/407754-modding-faq-common-mods/
https://linustechtips.com/topic/479667-cm-storm-scout-2-modding/#findComment-6435470
