My First PC Build (Help)
Solved by Bazilias,
Your build is fine. The only issue is that your RAM is 1866MHz but the motherboard only supports 1600 so that means that your RAM will be underclocked to 1600MHz. And you don't need a 650W power supply 500/550 Watt will do just fine. Try to go for an Scythe Mugen 4 or Coolermaster Hyper 212 EVO CPU cooler.
PopsicleHustler ·
Posted in Audio1 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory10 -
11
play_circle_filled
Latest From ShortCircuit:
