Single fan case choice?
Solved by Senzelian,
In a single rear fan case would positive air pressure by intake be better or negative air pressure by exhaust be better?
As long as it is filtered I would use it as an intake.
That way you don't have any parts that pull dust into the case.
If it's not filtered it doesn't matter.
PopsicleHustler ·
Posted in Audio0 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
play_circle_filled
Latest From ShortCircuit:
