Hi Guys,
I have a Sapphire R9 290 Vapor-X 4GB card. This card is awesome for me, I can play my games at ultra settings on 1080p. Now the thing is, I got myself a Nvidia Shield Android TV. So now in order to play my desktop games on my Shield I need a Nvidia Card. What Nvidia card is a good replacement for my R9 290? I know that a good comparison could be a GTX970 however that is out due to the  3.5GB Vram issue. How about a EVGA GTX980 maybe?
Thanks.
https://linustechtips.com/topic/478761-replacement-for-r9-290/
GTX 980 is solid - pricey but solid.
https://linustechtips.com/topic/478761-replacement-for-r9-290/#findComment-6415496
Either go for the 970 or the 980ti.
Not much need for anything over a 970 for 1080p. Then going for a 980 is quite pointless at this minute in point, better off spending a bit more and getting the 980ti instead.
There is always the option of looking at second hand cards as well.
CPU: i7 8700k   Motherboard: Asus Maximus Hero  RAM: 16GB @ 3600Mhz  GPU: MSI 980Ti 6G  Case: Fractal Design R5 (4 Intakes/3Exhausts)  Storage: Crucial BX100 SSD, Samsung 850 & Seagate 2TB HDD  PSU: Seasonic M12II Evo '850W'  CPU Cooling: Corsair H110i GT
https://linustechtips.com/topic/478761-replacement-for-r9-290/#findComment-6415516
980 isn't comparable to the 290 the 980 is much better.
check out the GTX 770
The 770 would be a significant downgrade from a 290. A GTX 770 performs about as well as an R9 280X. I'd say go 970, OP. The VRAM "issue" isn't really an issue.
https://linustechtips.com/topic/478761-replacement-for-r9-290/#findComment-6415861
There is no "issue" the card still performs great, hell my 780ti only has 3gb and I play all my games at 1440p ultra!!
The 980 is a great card too and better than the 290
btw shield streaming is awesome make sure you have a decent router though
https://linustechtips.com/topic/478761-replacement-for-r9-290/#findComment-6415939
I meant 780 ti.
Uh uh. Those are hard to find and still cost a ton in Singapore. The only options left are used.
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
https://linustechtips.com/topic/478761-replacement-for-r9-290/#findComment-6416157
Thanks for the advise guys. I was thinking of getting a card that is also "future proof" so hence figured the 980 is a better bet than 970. Also should I hold out and wait for the new GPU to release? I think Pascal chips should be out next year? Maybe there will be a GTX X80 :lol:
I can use GeForce Now for the time being I guess.
https://linustechtips.com/topic/478761-replacement-for-r9-290/#findComment-6416216
