Hello!
Fast question, will the XFX R7970 run in crossfire with the Radeon HD 7970 GHz Sapphire or an XFX Radeon HD 7970 or the Radeon HD 7970 MSI.
Thinking about running two cards and its the first time doing it so i need some advice :)
I got an XFX R7970
http://imgur.com/5WxgJ1w
Mobo: asus crosshair iv extreme
Will any of these run in crossfire with it?
XFX Radeon HD 7970.
http://imgur.com/Y1FRzlq
Radeon HD 7970 MSI
http://imgur.com/og8pkFk
http://imgur.com/lfSFUAS
Sorry for the stupid question, i just wanna be sure before i buy something :)
Thanks
The right man in the wrong place can make all the difference in the world.
https://linustechtips.com/topic/478485-amd-crossfire-help/
Yes but I think they would operate at the lower frequency of the two cards (if there's a difference).
That's incorrect, you're thinking SLI. I operate two different cards, a 290/390 crossfire and they run at their own core and memory frequencies. They do run smoother if I set the core frequencies to match. But the memory I leave at 1400/1500.
If anyone asks you never saw me.
https://linustechtips.com/topic/478485-amd-crossfire-help/#findComment-6411382
