I have an i5-3570k and using a CM hyper evo 212 to cool it. I have a slight OC, nothing major. But my idle temps are about 50c. Is that too high? Maybe I am just over thinking it!
01101100 01110110 01101100 00100000 00110101 00100000 01101101 01100001 01100111 01101001 01101011 01100001 01110010 01110000
https://linustechtips.com/topic/478254-high-idle-temps-for-cpu/
Idle temps don't matter.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/478254-high-idle-temps-for-cpu/#findComment-6407643
Load is around 70-80 IIRC. I'd have to check when I get home. Just seems high on both.
Reapply thermal paste because it shouldn't be running that hot under load.
https://linustechtips.com/topic/478254-high-idle-temps-for-cpu/#findComment-6407656
What is your voltage on? If it's on manual turn it to adaptive
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
https://linustechtips.com/topic/478254-high-idle-temps-for-cpu/#findComment-6407657
ivy bridge CPUs are notoriously hot, idle and load.
Look into this: https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&es_th=1&ie=UTF-8#q=delidding%203570k&es_th=1
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/478254-high-idle-temps-for-cpu/#findComment-6407661
Is it declocking when idle..?
If not thats likely the cause.
Open CPU-Z and it should show you the realtime frequency currently in use, updated every second or two.
Declocking on idle, it should be in the 30-45*c range temp wise (depending on ambient temps, hence that wide range)
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/478254-high-idle-temps-for-cpu/#findComment-6407662
I did that. I am having trouble sitting the cooler completely on the cpu. No idea why! I usually have no issues.
I didn't change the voltage. I think I have it at a stable 3.9 OC.
https://linustechtips.com/topic/478254-high-idle-temps-for-cpu/#findComment-6407667
That's pretty freaking toasty. Check your mount and thermal paste, if needed.
Why would you even do that.... SpeedStep is pointless on everything other than laptops, and some smaller form factor desktops. And even then, voltages impact temps more than frequency does, generally speaking.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/478254-high-idle-temps-for-cpu/#findComment-6407670
Your PC power settings may have been set to Performance Mode, and that disables Intel QuickStep which downclocks your CPU when idle.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/478254-high-idle-temps-for-cpu/#findComment-6407674
But is it declocking on idle desktop?
https://linustechtips.com/topic/478254-high-idle-temps-for-cpu/#findComment-6407675
I know it doesn't declock. IS there a setting in the bios to turn that on?
https://linustechtips.com/topic/478254-high-idle-temps-for-cpu/#findComment-6407676
Yep, but the name can vary depending on motherboard maker, usually the common term is Speedstep (if found, enable it and go back to windows)
Usually in the 'Advanced" section of the bios, under CPU settings, or maybe the CPU settings without needing to go to advanced.
Peruse through your bios, it will be there somewhere, if your lost, your manual would tell you, if you don't have it, you can get it online at the motherboard support webpage.
Win7 has finer control of idle frequencies too, in Advanced Power settings, But thats missing in W8 onwards I think and it is 0% min anyway,......In Win7 setting the min-cpu to 0% = 800mhz idle, if I set 60% it declocks to 2.5Ghz, which is where I leave it, and of course the max-cpu frequency should be 100%.
Mine is on High Performance, and declocks fine, it does not disable Speedstep.
https://linustechtips.com/topic/478254-high-idle-temps-for-cpu/#findComment-6407684
Even load seems toasty. I did have to replace the CM stock fan with a random fan from bestbuy after it stopped working. I plan on getting better fans for it. Which I hope will help. Or I will get a nhd-14 for $75.
https://linustechtips.com/topic/478254-high-idle-temps-for-cpu/#findComment-6407701
It's about right IMO, Hyper coolers are great, but not the best, and with a single fan, depending on your fan curve (how fast it ramps up) that could very well be normal without further tweaking.
My locked 3.9ghz i5, with the old hyper I used to have, quickly got to 71*c and further climbed to 75*c+ when heat had pooled in the case when gaming.
I fully agree, but I am in a small room myself with literally a max-operable quarter foot wide window., 50*c idle is shit in this room for prolonged uptime.
Which is why I have it enabled (half) @ 2.5ghz idle and temps stay at 40*c, not 50*c.
https://linustechtips.com/topic/478254-high-idle-temps-for-cpu/#findComment-6407711
80C on load for ivy is normal-ish.
https://linustechtips.com/topic/478254-high-idle-temps-for-cpu/#findComment-6407715
All righty! Thanks! I still plan on upgrading the cooler soon. I've had the bad boy for a few years.
https://linustechtips.com/topic/478254-high-idle-temps-for-cpu/#findComment-6407720
Adding a 2nd decent quality fan to the hyper (Push/pull) will take another 2-3*c off the top usually, but will add more fan noise with it.
https://linustechtips.com/topic/478254-high-idle-temps-for-cpu/#findComment-6407749
NF-F12....
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/478254-high-idle-temps-for-cpu/#findComment-6407767
