Right now I'm thinking of getting an i3-4160 and a R9380. Will the CPU bottleneck the GPU?
Get an i5 if you're going to be gaming.
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
https://linustechtips.com/topic/478115-will-i-bottleneck/#findComment-6405849
That's an interesting combination to consider. What's your budget? And are you looking to buy only the motherboard/processor, GPU, and memory, or do you need more on top of that?
Wife's build: Amethyst - Ryzen 9 3900X, 32GB G.Skill Ripjaws V DDR4-3200, ASUS Prime X570-P, EVGA RTX 3080 FTW3 12GB, Corsair Obsidian 750D, Corsair RM1000 (yellow label)
My build: Mira - Ryzen 7 3700X, 32GB EVGA DDR4-3200, ASUS Prime X470-PRO, EVGA RTX 3070 XC3, beQuiet Dark Base 900, EVGA 1000 G6
https://linustechtips.com/topic/478115-will-i-bottleneck/#findComment-6405853
I want an i5 but their too expensive cause Australia likes to tax the hell out of things. An i5-4460 is worth $260 ish
get the used one
Key Switches Guide | LLT Beginner Guide | GPU TDP & Power Consumption Explained | PSU Tier
s a d b o y s 2 0 0 1
https://linustechtips.com/topic/478115-will-i-bottleneck/#findComment-6405861
Well in that case there is no point you asking us if it will bottleneck or not. Just buy the equipment you want then get an upgrade down the line if you fall into problems.
Chernobyl
Kraken
https://linustechtips.com/topic/478115-will-i-bottleneck/#findComment-6405864
While I'm at it is it worth the extra $100 to be able to over clock the i5 k series CPU, or is it better to just get the i5-4460?
https://linustechtips.com/topic/478115-will-i-bottleneck/#findComment-6405871
Not in GPU bound games, Yes in some CPU bound games (to some degree) it really DOES depend on the game and how it handles cores/threading.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/478115-will-i-bottleneck/#findComment-6405926
I'm biased, I prefer overclocking, I will never buy a locked CPU for gaming etc, locked chips are for workstations.
Chernobyl
Kraken
https://linustechtips.com/topic/478115-will-i-bottleneck/#findComment-6405956
You dont get $100 of extra performance, maybe 5-10% better CPU performance, so..its hard to say its worth it
a 4460 and h81 board is a cheap way to get a lot of gaming performance
https://linustechtips.com/topic/478115-will-i-bottleneck/#findComment-6406237
Says the guy with an unlocked CPU he isn't even overclocking...?
Chernobyl
Kraken
https://linustechtips.com/topic/478115-will-i-bottleneck/#findComment-6408009
So what? its not  creating a bottleneck so it makes no difference,
(also I believe that the automatic overclocking on my MSI board is on)
as it stands, a 4460 to a 4670k you are not getting $100 MORE performance, especially if it means eating into budget for memory, SSD, or GPU - which are arguably as important as a tiny bit of clock speed
https://linustechtips.com/topic/478115-will-i-bottleneck/#findComment-6408051
SNIP
Whatever :) at least I dont have an FX8350 or crappy kingston ssd now SSD
(ok that was harsh)
but seriously, not everyone needs to sit around OCing all day to get a decent PC
https://linustechtips.com/topic/478115-will-i-bottleneck/#findComment-6408077
Lmfao at least I didn't spend more money on features I'm not using...
Who said I am never going to use it?
4770 = £230
4770k = £260
I was buying a Z series ANYWAY board for Msata SSD and RAID 10
So it cost me £20
the cooler was for aesthetic reasons and was only £80 on sale anyway
So.... it probably cost me £40 in total more... and I have automatic OCing on, I just havnt pushed it because I dont feel the need
https://linustechtips.com/topic/478115-will-i-bottleneck/#findComment-6408116
Why did it get overclocked? oh noes i don't give a crap... I like my 80 bucks I just saved on a thing that wont break for 5 years if in not a retard........
k
CPU:Ryzen 9800X3D GPU: RTX 5080 MB: Asus ROG X870E  RAM: G.Skill Trident Neo 64gb CPU Cooler: ROG Ryujin III
https://linustechtips.com/topic/478115-will-i-bottleneck/#findComment-6438756
