Hello LTT. I'm building my first gaming PC soon, but will need to move it very frequently. Will my computer be safe in the cheaper Corsair 100RR case, or should I buy the more expensive Corsair 380t (designed for portability), but become broke? I also need a recommendation for a reliable PSU that can power 2 r9 390s, an i5-4460, and 8gb of DDR3 RAM
https://linustechtips.com/topic/477873-casepsu-help/
For your PSU an 850W EVGA GS/G2 should be good. For the case I wouldn't get something with a side panel window. More likely to break a panel doing that.
https://linustechtips.com/topic/477873-casepsu-help/#findComment-6402825
My case needs to have a side panel window. If I transport the case on the other side, would you say that's safe, or should I just pay the extra for the more portable 380t?
https://linustechtips.com/topic/477873-casepsu-help/#findComment-6402860
TBH I would spend the extra money on the 380t.
https://linustechtips.com/topic/477873-casepsu-help/#findComment-6403884
