I would love to be in the $1500 range but that does not seem very possible for my purposes. You can read the description and look at the build here. http://pcpartpicker.com/p/B8p47P Thanks for your time
P.S I'm only 15 and my main source of income will be working over the summer. I already have $400 set aside for it.
https://linustechtips.com/topic/477564-help-better-my-pc-build/
I would love to be in the $1500 range but that does not seem very possible for my purposes. You can read the description and look at the build here http://pcpartpicker.com/p/B8p47P. Thanks for your time
So....what's the budget? not $1500?
https://linustechtips.com/topic/477564-help-better-my-pc-build/#findComment-6398431
Are you gonna overclock? I doubt it if its your first build though..
https://linustechtips.com/topic/477564-help-better-my-pc-build/#findComment-6398442
Hello and welcome to the forums :D Please remember to follow your own threads.
What will the build be used for? Also there's a period at the end of the link breaking it.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/477564-help-better-my-pc-build/#findComment-6398443
Around $2000
Would be nice if I could go less but it hard to decline some of the things. But if something is unessescary plz point it out like if a motherboard doesn't give any real advantage over a cheaper one.
https://linustechtips.com/topic/477564-help-better-my-pc-build/#findComment-6398452
Around $2000
That's a good budget. Just checking, you won't overclock, will you?
https://linustechtips.com/topic/477564-help-better-my-pc-build/#findComment-6398458
Around $2000
Yes you overspent on the motherboard. What will the purpose of this build be? Oh, and,
USEFUL LINKS:
https://linustechtips.com/topic/477564-help-better-my-pc-build/#findComment-6398480
Here ya go.
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor  ($179.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H97-HD3 ATX LGA1150 Motherboard  ($83.70 @ SuperBiiz)
Video Card: EVGA GeForce GTX 980 Ti 6GB Video Card  ($639.99 @ SuperBiiz)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($99.99 @ Amazon)
Total: $1313.09
Generated by PCPartPicker 2015-11-01 20:09 EST-0500
https://linustechtips.com/topic/477564-help-better-my-pc-build/#findComment-6398482
Here you go. You don't need to overclock IMO and the GPU is for in case you need to game since you said that you will use it for work
CPU: Intel Core i5-6600 3.3GHz Quad-Core Processor  ($205.99 @ SuperBiiz)
Motherboard: MSI Z170 Krait Gaming ATX LGA1151 Motherboard  ($129.99 @ SuperBiiz)
Video Card: Sapphire Radeon R9 380 4GB Nitro Video Card  ($213.98 @ Newegg)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($59.99 @ Micro Center)
Total: $952.91
Generated by PCPartPicker 2015-11-01 20:10 EST-0500
https://linustechtips.com/topic/477564-help-better-my-pc-build/#findComment-6398501
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR4-2400 Memory ($52.99 @ Amazon)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($87.99 @ Amazon)
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive ($106.99 @ Newegg)
Power Supply: EVGA SuperNOVA GS 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($94.99 @ Amazon)
Total: $952.91
Anyone got any info for mother boards and graphic card changes. Thanks.
https://linustechtips.com/topic/477564-help-better-my-pc-build/#findComment-6398523
I may but I won't be that dedicated to it. I hope to stay away from it. But I will probably need to render videos as well as CAD and 2 motitors.
You're 15...no offence but you'll be doing CAD and you need 2 monitors???
https://linustechtips.com/topic/477564-help-better-my-pc-build/#findComment-6398563
Since you said you will doing CAD and 2 monitors, I changed a little bit and all the price is from Newegg
Motherboard: MSI Z170 Krait Gaming ATX LGA1151 Motherboard  ($144.99 @ Newegg)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($76.98 @ Newegg)
Total: $1326.89
Generated by PCPartPicker 2015-11-01 20:24 EST-0500
https://linustechtips.com/topic/477564-help-better-my-pc-build/#findComment-6398590
I may be able to ditch the mike setup for something cheaper.
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($61.20 @ SuperBiiz)
Case: Raidmax ATX-502WBG ATX Mid Tower Case  ($72.98 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($89.88 @ OutletPC)
Monitor: Asus PB258Q 60Hz 25.0" Monitor  ($308.99 @ SuperBiiz)
Mouse: Logitech G300S Wired Optical Mouse  ($21.99 @ NCIX US)
Headphones: Audio-Technica ATH-M30x Headphones  ($69.00 @ Adorama)
Total: $1529.52
Generated by PCPartPicker 2015-11-01 20:28 EST-0500
Modify this to your liking.
https://linustechtips.com/topic/477564-help-better-my-pc-build/#findComment-6398625
