pc build help
Solved by Ophidio,
do you recommend OCing it? or just get slower ram
so just go for 1intel 750 400gb and 2x2tb wd black?
yes, the performance you will get from the Intel 750 will make the other SSD look like a normal HDD. The Samsung 850 is a good sata SSD but compared to a Intel 750 it's just an expensive HDD.
As for your other question honestly just get slower RAM. You won't even be able to notice a difference between the speeds, just go with the highest the mobo supports without OCing.
